'00-05 Dash Pad
Old Feb 26, 2013 | 11:28 AM
rj's Avatar
rj
Default '00-05 Dash Pad
I see you guys customizing the dashes in your cars all the time.
How does the upper part of the dash pad come loose from the sub structure?
I need to replace the ignition switch in a 2003 Pace car. In hopes this will cure the passlock system woes.
I can get the lower parts of the dash apart on the drive side. But it looks like the pad needs to come loose around the climate controls and stereo to get the ingition switch.
Old Feb 26, 2013 | 12:24 PM
You mean the front of the dash? Theres srewes at the bottom under the steering wheel, one in the glove box & one on the fuse cover side, put tge steering wheel all the way down, pop the ign cover off turn the key on put it in nutral & pull it off by working your way around
mdc1022
Mar 16, 2013 06:13 PM
mrl390
May 30, 2010 03:43 AM
Endo
Mar 9, 2010 12:14 PM
04 Intimidator
Jun 8, 2008 10:51 AM
thesheiladivine
Apr 27, 2008 12:16 AM
