ZZP Downpipe
Old Mar 21, 2009 | 07:53 PM
  #31
04 Intimidator's Avatar
Originally Posted by jaws2008
the code appeared today i also filled up the gas tank for the first time. any recommendations on clearing the code.
2 ways of doing it. The first is to get a $70 to $100 OBD2 Scanner and clear it every time it comes up - for me it was about once every 2 weeks.
The other is to get/use a programmer to disable the code.
Old Mar 21, 2009 | 11:07 PM
  #32
Originally Posted by 04 Intimidator
Amy - the emulator will work for your 03 if you get the downpipe but it won't be emissions legal. The emulator won't work at all for your 05. Starting in 04 the Monte O2's started measuring the heat of the exhaust as well as the oxygen. The emulators only measure oxygen.
Thanks for the info. I did a little more reading on the emulator and did notice that it wasn't compatible with the 05. As for the programmer I will need to find someone local with a programmer. Biggriggs knows someone not too far from where I live with a Grand Prix that might be able to help me.
Old Mar 22, 2009 | 08:57 AM
  #33
I could do the programming part, but I don't have your year opened up and it's a $100 to do that. It's also quite a drive to mid Wisconsin.
Old Mar 22, 2009 | 07:39 PM
  #34
Thanks. If I can't find anyone in my area with the tuner I guess I won't be able to do this mod. I saw the Random Technology 3" downpipe with high flow cat on 3800 performance but it's twice the money . But it does claim that it won't throw a code. I probably will just get the U-bend delete and Dynomax cat back.
Old Mar 22, 2009 | 07:51 PM
  #35
The U-Bend delete and Dynomax will sound and perform well. You won't get any performance bonus from the Dynomax but as you know they sound good.
As for the Random Tech pipe they are full of it. That sucker throws codes left and right. I was clearing the P420 code about once every 2 weeks.
Old Mar 22, 2009 | 08:14 PM
  #36
I wonder if the SLP catback would add any performance. It's $100 more than the Dynomax but it's stainless steel.
Old Apr 17, 2009 | 07:51 PM
  #37
aussiek2000's Avatar
Will the 2.5" downpipe with cat work on 3.4l?
Old Apr 18, 2009 | 03:25 AM
  #38
biggriggs's Avatar
You could email zzp, but I doubt it that the connection at the manifolds is the same.
You can definitely do the u-bend delete. For the 3.4L though, you won't see nearly as much of a gain as you will with the 3.8L.
-Riggs.
Old Oct 9, 2009 | 09:30 PM
  #39
tiresmokindad's Avatar
hello everyone.
Old Oct 9, 2009 | 09:32 PM
  #40
Sorry for my ignorance, I really need help. I was confused if the magnaflow catalytic converter is pretty good?and also where to buy? I do some searched, inguiry and I tried it here Magnaflow Catalytic Converter . Anyone tried it here.? Any suggestions, please let me know. Thanks.
