Wizaired Cold Air Intake Review
Old Jan 1, 2010 | 06:42 PM
  #61
well i thought we had a good game tonight...
haha jk
i got it from ZZP, i did the install, it took about an hour and an half, it was a pretty easy install, it was just cold in my garage so it didnt help to make things easy, the hardest part was just sliding in the walls of the intake and getting the screws to line up, that took about a half hour, because i have huge hands and cant fit them into small spots ha
but you also have to slide the pcm through a slot which made it kind of hard to align the walls of the intake
other than that, the install was really self explanatory and pretty straight forward, just read the directions carefully when you do it
Old Jan 3, 2010 | 12:57 AM
  #62
Jomao_o's Avatar
Thanks Trewyn.
That kit makes the engine bay look a lot cooler too!
Old Jan 3, 2010 | 01:01 PM
  #63
werewolf-odst's Avatar
Originally Posted by trewyn15
like the smoked out tails. cant wait to get mine.
about your filter, is it the wizzard housing and duct, but you put on an k&n filter?
it looks like there is foil on it also, did it pose a problem putting it o with that thing at the bottom of the filter housing.
Old Jan 3, 2010 | 05:54 PM
  #64
thanks jomao
and sugardaddy =p...it is the wizaired housing and duct and also the k&n that they suggest for it, and are you talking about the foil or the other thing on the bottom?
the foil on the bottom didnt pose a problem at all, but the other thing, the pcm, did pose a little problem, but if you just read the instructions on putting it in, it makes it a little easier, the hardest part was lining up all the little screw holes, other than that it was pretty easy
Old Jan 22, 2010 | 03:30 PM
  #65
Jordanshedd5's Avatar
Default PCM Tray?
Does the Wizaired CAI have a place for the PCM? The MSP CAI on Milzys has a PCM tray...
Does it matter if the PCM even need a tray?
Old Jan 22, 2010 | 03:35 PM
  #66
Yes the wizaired has a spot for the PCM. You can see it under the filter
Old Jan 22, 2010 | 11:18 PM
  #67
its kinda hard to see but its the flat silver part down there
Old Jan 23, 2010 | 06:48 AM
  #68
Default Cone Size
YUP. there it is. I didnt see it before. I have read that some people have fit different sized air filters in there... I have a 9 inch K&N cone... will that fit? There is an option for a 4 inch K&N on the zzp site, is that the diameter?
Old Jan 23, 2010 | 10:53 AM
  #69
thats the diameter the one in my pic is the 9 inch, you have to work it in but it fits
Old Jan 23, 2010 | 11:04 AM
  #70
I think I have a nine inch cone too on my CAI and it is a challenge to get it out to clean it.
