Wizair Help
Wizair Help
Well guys i recently picked up a wizair CAI box from a guy over on clubgp. The install didnt go as smoothly as i planned but either way i got it installed. I am wondering what i could use for intake tubing to run from the box to the throttle body. Any ideas? I do not think that the replacement wizair on zzp is worth forty bucks but the stock tubing simply will not work. Any help would be appreciated. Thanks.
So it didn't come with an intake tube? Make sure you get something that doesn't conduct heat. In the Wizaired install in the 3800 the sensor gets plugged into the box its self.
if your looking at your engine from the front of your car it should go in the top left corner there should be a little spot, you could also contact zzp and see if they have any of the tubing, i would assume they do because they have the random different pieces sitting around for the 3800 and 3400 models, or else they may be able to fab you something that doesnt conduct heat.
do you have pics of yours?
wizaired install.........
....Go to the How to Section and scroll down to Wizaired Install.
I took several photos of step by step instructions. I know that you have only the box but it should give you a idea of where everything goes..... ?
Good luck.
Good luck.
http://intense-racing.com/Merchant2/...3800_Induction
or
http://www.frozenboost.com/index.php...d8fd839867d6eb
