Winter Project 2: FWI
Old Dec 20, 2012 | 09:58 AM
zzapultimate's Avatar
Lookin good man
Thanks!
Originally Posted by burgundybullet
Is yours one of the oiled ones or is it the dry one?
It's Dry.
Originally Posted by BlownUptoHigh
hey wuts that vacuum line that runs into the fenderwheel is that that hvac and what it connect too?
I think I know what line you're talking about. I'm not 100% sure but I think it goes down to a vacuum ball that has to do with controlling the HVAC system.
looks good, very nicely done......
Thanks
Looks Good
Thanks Mike
Looks good, pretty cool that the roof flange works so well like that.
Works great.. just the right size
Old Dec 20, 2012 | 11:16 PM
Looks good!
I'd grind that rust all the way down, then coat it and paint it
Old Dec 20, 2012 | 11:48 PM
MonteCarlSS's Avatar
Looks good man! Nice job on making it yourself
Old Dec 21, 2012 | 01:01 AM
Originally Posted by trewyn15
Looks good!
Planning on it. Only, I have no idea what the color of my engine bay is it obviously doesn't match the body color because it's not metallic
Thanks. If I can't do it myself, I usually don't do it
Old Dec 21, 2012 | 02:30 AM
Looks good the only thing is in my research on building one of these I seen a lot of info about PVC pipe producing a lethal gas or giving off chemicals when it gets hot. I think people say to use ABS plastic pipe instead. Again I have no first hand proof of this, it is just what I read on the web.
Old Dec 21, 2012 | 10:38 AM
Yes Chibi
I've read that too. Not that I don't believe it, but I don't think it will get very hot. I mean the inside of the pipe has ambient temperature air flowing through it which should keep it pretty cool. I don't know how hot it has to get to release gasses, but I'd imagine at least two or three hundred degrees?
Old Dec 21, 2012 | 11:38 AM
It's around 200 degrees, and our cars run a 195 thermostat and fans don't kick on until 212... well in that range for under the hood temps
Also ABS is already black, and the couplers are already made from ABS. Why not just continue the path
That filter also looks extremely small. You actually might have less surface there than you did with the stock system. Can you get a bigger filter in there?
Old Dec 21, 2012 | 12:08 PM
Its the same color they usually leave the metallic & pearls out
Old Dec 22, 2012 | 01:42 AM
I have nothing against ABS.. PVC was just much more available. Where do you buy ABS?
Perhaps I should test it this summer.. It wouldn't be hard at all to see what the temps on the PVC tube are on a hot day.
There isn't much room for a filter. I might be able to squeeze one size bigger, but is that really going to make a difference? I'm not going for any huge performance gains.. I have a 3100 after all
Interesting. Is that paint available for purchase?
Old Dec 22, 2012 | 08:23 AM
BlownUptoHigh's Avatar
yeah i thought u were going to stick the filter actually down inside the fenderwell not just against the wall, still look good though although the filter might become a restriction
