Wideband Sensor
Old Mar 11, 2013 | 06:20 PM
Bait's Avatar
If you tune in open loop you can put the wide band in place of the upper o2 sensor but if you are tuning in closed loop you will need the upper o2 sensor and will need to install another o2 bung for the wide band. The wide band doesn't come with a o2 bung you would need to buy one separately and drill your down pipe and weld the bung on.
That makes a big difference.
Since I have no clue, which is better?
Old Mar 11, 2013 | 11:05 PM
turbo monte's Avatar
Turbo Monte is tuned in open loop. It takes way more time tuning open loop but the end result I feel is better. Just my opinion.
More less open loop tune means you tune the pcm to do what you want and it doesn't use o2 sensors to make adjustments you make the adjustments.
Closed loop the sensors will tell the pcm to adjust the pcm tables if it feels it is needed.
Old Mar 11, 2013 | 11:12 PM
Bait's Avatar
Last question for at least awhile, is it still a weld in or just a standard screw in?
How do you run the wire inside?
Old Mar 11, 2013 | 11:37 PM
The wideband sensor will screw into the existing o2 bung if you tune open loop. If you tune closed loop you will need to drill a hole in the down pipe and weld the o2 bung over the hole you drilled and then the wide band you screw right into the new bung. Use anti cease on the threads so if you need to take it out it will be a little easier to do.
On a wide band the gauge goes in the car and you run the wires from the gauge to the wide band o2 sensor. On the wide band o2 sensor there is wires coming out of it as well. There is connectors on both ends. Connect them. You will also need to get a power source so the gauge lights up (ignition wire) and ground the gauge.
Old Mar 11, 2013 | 11:40 PM
Bait's Avatar
Thank you. You guys have been a tremendous help.
Old Mar 11, 2013 | 11:42 PM
No problem man glad we could help
dgm
Feb 12, 2015 08:30 PM
Ace25
Jan 10, 2013 11:32 AM
BeachBumMike
Jul 14, 2007 04:19 PM
rcohen
Feb 12, 2007 08:49 PM
