Wideband Sensor
Old Jan 17, 2013 | 11:13 AM
Bait's Avatar
Default Wideband Sensor
Which wideband sensor is the most reliable and accurate to use.
AEM Wideband Failsafe Gauge
AEM Wideband O2 Sensor
Innovate LC-1 Standalone Wideband Controller
I would like to hear from a few different people to receive more accurate information.
Thanks again.
Old Jan 20, 2013 | 11:56 PM
Bait's Avatar
Bump.
Old Feb 12, 2013 | 07:56 AM
Bait's Avatar
Bump. Still looking for help.
Old Feb 12, 2013 | 11:26 AM
S.O.G.'s Avatar
I would go with AEM wideband o2 sensor
Old Feb 12, 2013 | 02:09 PM
turbo monte's Avatar
i have the aem wideband and have had no issues this far.
Old Feb 13, 2013 | 07:53 AM
Bait's Avatar
How long have you had the sensor in?
Old Feb 13, 2013 | 09:03 AM
AEM is what I use all the way around now for over 4 years, never an issue....
Old Feb 13, 2013 | 11:51 AM
Mine is 2yrs old but only has about 2,000 miles on it
Old Mar 11, 2013 | 05:29 PM
Bait's Avatar
Hey guys,
For WB O2 sensor does it go in factory location or is a new hole needed?
If so O2 Bung Plug from ZZP? Is the O2 Bung needed or does it come with the AEM?
Thanks again for your AWESOMENESS!
Old Mar 11, 2013 | 06:05 PM
If you tune in open loop you can put the wide band in place of the upper o2 sensor but if you are tuning in closed loop you will need the upper o2 sensor and will need to install another o2 bung for the wide band. The wide band doesn't come with a o2 bung you would need to buy one separately and drill your down pipe and weld the bung on.
