Why get a Performance Exhaust ?
Old Feb 22, 2009 | 01:46 PM
Default Why get a Performance Exhaust ?
[align=center]
Why should I buy a performance exhaust system?[/align][align=center]
[/align][align=center]Good Read/Infor [:-]Click below[/align][align=center][:-]Source Link below [:-][/align][align=center]http://www.autoanything.com/exhausts-mufflers/50A6A116A1.aspx[/align]
Old Feb 23, 2009 | 07:00 AM
TonySS2007's Avatar
Default RE: Why get a Performance Exhaust ?
KidSpace
Thanks for the link that was a really good read. Lots of information.
Old Feb 23, 2009 | 03:07 PM
ORIGINAL: TonySS2007
KidSpace
Tony, you are Welcome 4 Sure.
Are you thinking about a performance exhaust for your SS ?
_____________________________________________
Below is a Thread Created by Mod Wiz Kidd `Josh,
on members exhaust clips
Click below & check them `out, and post your exhaust
clip `if you have one...Thanks
hey, if anyone has sound clips of their exhaust can you post them and what mufflers are on it??? i'm .... The Monte Carlo name is a copyrighted trademark / sales mark of the Chevrolet Motors Division of General Motors.
www.montecarloforum.com/m_24749/tm.htm - 72k - Similar pages
ExhaustSoundClips.com - Hear it before you buy it! - Mazda E...
Listen to sound clips from many manufacturers of exhaust system on any car, truck, ... chevy monte carlo stock muffler .... rv 454 chevrolet header exhaust ...
www.exhaustsoundclips.com/search_terms.html - 431k - Similar pages
Old Feb 24, 2009 | 05:19 AM
[align=center]Exhaust Tips and Tricks [/align]
Subjective style and sound
[align=center][/align]
by Mike Bumbeck
Exhaust tips are one of those items that bridge the gap between the two worlds of automotive performance and visual style. What makes exhaust tips unique is that along with adding a visual finishing touch to the exhaust system and vehicle, they also provide an aural punctuation. The shape and construction of the exhaust tips affect the overall tone of the exhaust note, and can affect exhaust flow as well. The other aspect of exhaust tips is that like a set of wheels, they are an entirely subjective finishing touch to the exhaust system of a car, truck, SUV, or station wagon.
One person's idea of the ultimate exhaust tip is another's idea of an automotive abomination. As a result of the millions of different people in this world who drive motor vehicles, there is a bewildering array of exhaust tips available. Tapered to trumpet. Mellow to megaphone. Single. Dual. Triple. Quadruple. Square. Round. Oval. Even tips molded into the shape of the Chevrolet "bowtie" are remarkably easy to acquire. The list goes on and on. Everything from basic single wall tapered tips to triple wall lit-up-from-the-inside by different colored neon monster tips are all a phone call, mouse click, or trip to the store away from being bolted up or welded onto any vehicle in no time.
Style Council
While exhaust tips are indeed one of the most subjective style points of any vehicle, there are still a few guidelines to follow when considering a tip change. If over-the-top is your style, then by all means get your hands on the biggest and loudest. No holds barred. If subtlety is your strongpoint, you must be careful not to tip the scales. Following the general direction of bodyline and predominant shape of the vehicle and mounting flush with the rear valance can add subtle yet unique style. Shape is also important. A swooping car with a great number of curves is not visually well served by square tips that extend beyond the curved valance. And so on. If you're a purist then stick with the classics, or go with what was the predominant style of the time. A period-correct upturned "stinger" exhaust tip looks right at home on a '70s-era Volkswagen Baja Bug, whereas it would look downright goofy on a '90s-era Corvette.
Finish and construction are also important considerations. Chrome finish exhaust tips have been known to chip and flake, as chrome doesn't handle extremes in heat very well. Stainless steel is more durable, and available in finishes from brushed to chrome-like polish. Titanium exhaust tips are often available already "blued" to simulate the extreme heat created by real life racing, and add a racy look to an otherwise street-going exhaust. The beauty of it is that, ultimately, exhaust tip choice is up to you. If you think it looks right, then it's right.
Function Over Fashion
Exhaust tips actually do play a role in the final sound of an exhaust. Where mufflers and resonators take care of the good majority of exhaust pulse cancellation and silencing, the exhaust tip can shape the remaining pulses and accompanying sound as it makes its final exit from the pipe. Much in the same way a Tuba sounds different than a Trumpet, a short megaphone exhaust tip will sound completely different than a long pencil-shaped exhaust tip. Some exhaust tips even add a small resonator to the equation to help mellow and deepen the exiting exhaust note. A perforated tube surrounded by sound deadening material puts one last mellowing touch on the exhaust pulses before they reach your ears and the ears of others.
Mounting can also have an effect on sound. A tip that is mounted with a compression clamp or welded on can provide a more solid sound than screw-on type tips. Screw-on tips mount in the same way a light bulb cover bolts onto the ceiling light fixture. Three bolts or screws hold the tip onto the end of the exhaust pipe. Finally, while claims of exhaust tips by themselves adding horsepower are numerous, these claims should be approached with great skepticism. Unless the tip being replaced is acting as a massive restriction to exhaust flow, replacing an exhaust tip is more an exercise in style and sound than noticeable horsepower gains.
[/align]
Old Feb 24, 2009 | 05:24 AM
[:-]Click on below links [:-]
Photo 1 The tip-less muffler held in place with a stand. The stock exhaust and dual tip muffler had disintegrated after 18 years of service.
[align=center]
[hr]
[/align][align=center][:-]Quick Jump To: [:-]
| 1 |
2931 | [/size]3840 | 4749 | 5658 | 6567 | 7476 | 8385 | [/align][/font]
Old Feb 24, 2009 | 06:22 AM
TonySS2007's Avatar
Hey KidSpace,
Yeah I just got a Magnaflow Cat-Back system this weekend and had it installed. What a difference in the sound and preformance. I was really shocked, at how much better it sounds and responds now.
I should have done this last year.
Old Feb 24, 2009 | 06:41 AM
Hi `Tony,
You are sure a lucky/fortunate man to have the last
year produced AweSome 2007Chevrolet Monte Carlo V-8 SS
I think MagnaFlow Systems (Stainless Steel) Exhaust
systems is one of the best for a professional built &
tuned systems for the Monte Carlo : )
I don't need a audio sound system `if my ride has
a super tuned exhaust....I really love hearingthe sounds of
a Chevy V-8 going through the gears, or hearing
the rumble while crusing
Wish you safe miles & great sounds.
`Space
Old Feb 25, 2009 | 05:16 AM
[align=center]Hi Members,[/align][align=center]Below link is a place to go to check on Mufflers +[/align][align=center]to give you some idea on cost.[/align][align=center][/align]
Chevy Monte Carlo Muffler
Product Description
WK18345 Walker Muffler 1981 - 1981 Chevrolet Monte CarloFit Info:
5.0L, V8, GAS, CARB, VIN "H" - Base
[/b]
22070 Walker Muffler 1980 - 1980 Chevy Monte CarloFit Info:
3.8L, V6, Turbo, GAS, CARB, VIN "3" - Sport
[/b]
843041 Flowmaster Muffler 1976 - 1976 Chevy Monte CarloFit Info:
5.7L, V8, Gas, Carb, VIN 'V'
[/b]
WK17840 Walker Muffler 1985 - 1988 Chevrolet Monte CarloFit Info:
4.3L, V6, GAS, FI, VIN "Z" - Base
[/b]
Performance Mufflers
Walker Mufflers
Flowmaster Mufflers
MBRP Mufflers
Flowtech Mufflers
Stock Mufflers
Bosal Mufflers
Bosal, Flowmaster, Flowtech, MBRP, Walker Mufflers are available for the following Chevy Monte Carlo years: 07, 06, 05, 04, 03, 02, 01, 00, 99, 98, 97, 96, 95, 88, 87, 86, 85, 84, 83, 82, 81, 80, 79, 78, 77, 76, 75, 74, 73, 72, 71, 70.
[align=center][:-]Click below link for above + Parts for the Monte Carlo[:-][/align][align=center][:-][/align][align=center]http://www.car-stuff.com/mmparts/chevy-monte_carlo/muffler.html[/align]
Aug 31, 2013 04:54 AM
Brian Kolecke
Jun 24, 2013 08:53 PM
08RedSS
Feb 18, 2013 08:43 PM
Budsjlm
Feb 15, 2011 12:21 PM
augi
Feb 13, 2011 08:15 PM
