What are the symptoms of a leaking Lower Intake Manifold Gasket?
I looked at RockAuto, I believe the aluminum LIM gaskets I used was FelPro part number MS98014T.
Do not forget to ALSO get the UIM gasket. Some may re-use these, I opt NOT to. Dorman makes a good UIM kit. Includes all the little gaskets you should have while doing this. Also, buy new coolant elbows (they are $5, and will probably bust when removing or are old enough they should be changed while you are in that area).
OH, I did not realize you were in Canada. Sucks how much the over the border shipping costs....
Keep in mind, you can still use RockAuto as a great list for parts and part numbers. Also if you have questions, they're e-mail responses are rather fast.
When I was getting the parts to have my 2004 Dale Jr done, I bought my parts at the dealer.
Here is the GM aluminum lower intake gasket #89017825 and here are the GM valve cover gaskets #24503937. The valve cover gaskets are supposed to be the new revised ones for the supercharged cars so I don't know if this number will work for the N/A cars or not.
Here are the #'s for the coolant elbows for those who want to know. 24503423 & 12565082
Wayne
Wayne
How common is it for the lower intake to leak oil from the china walls?
The lower intake gasket was replaced 40k miles ago due to coolant disappearing. I've noticed oil has been leaking and found it's been leaking on both sides of the engine at the lower intake gasket where the sealant is ran inbetween both heads.
So, I'm guessing the sealant has failed, or wasn't completely cleaned up of grease before sealant was ran, or wasn't 100% sealed up. But since you usually see complaints of coolant leaking from the LIM gasket. I'm gonna assume the dealer screwed it up.
Sounds Good Im going to be attempting this LIM Gaskets and elbows First week of march as I have the hole week off. Ive seen Coolant By the Elbows Fresh and it seems oil/antiefreeze is comming around hole engine from LIM and lower.. Soo Only makes sence to change it all..
Thank you 70MONTE1 Lots of help thier with Part #
Jasonsmith (What Bolts are supose to be change and were doese this sealant go?)
So For complete Job on my 05 SS S/C I Would Need:
alum LIM gaskets - 2coolant elbows - 2 valve cover gaskets-
UIM gasket - Im guessing 6 Fuel injector o-Rings -
throttel body gasket <-Do I really need to remove it from supercharger?)
Anything Els? and Torw Specs would be Great I cannot seem to find Order and how tight.
thx
thx
Opinion Needed: After Lower Intake Manifold Gasket
Cruvolo93
Nov 22, 2014 09:26 PM
6th Gen ('00-'05): 3800 Lower Intake Manifold Gasket- EGR Stovepipe?
Dylan313
Apr 9, 2013 10:03 PM
