What do you think
Old Jun 29, 2009 | 04:00 AM
atg284's Avatar
Question What do you think
I stumbled across this on ebay...I sold the Camaro but now I have mod money
http://cgi.ebay.com/ebaymotors/2000-...Q5fAccessories
Old Jun 29, 2009 | 04:05 AM
atg284's Avatar
Found another one...kind of the same deal....I'm thinking the only downside is the metal tubing will heat up....buuuut I had a SLP CAI on the maro and it was metal and I loved that one
hummm $50 - $100 is better than $300
tell me what you think though im not itching to buy (yet )
Old Jun 29, 2009 | 04:42 AM
Hi Anthony,
Glad that you sold you Camaro & Have some Mod'$'s : )
I don't know if any member has purchased
the CAI you posted.
Check back on your Thread & see if anyone post.
I've found that you get what you pay for ?
Chevy Monte Carlo Short Ram Air Intake System
Fits 2000 - 2005 Chevy Monte Carlo models
List Price: $119.99
BUY IT NOW: $62.00
BlingLights manufactures its intakes from mandrel-bent, lightweight aircraft aluminum with a powder coated carbon-black finish, and Carbon Fiber Reusable Open Top Fabric Filter. BlingLights Short Ram intake systems delivers exceptional performance, value and ease of installation. Our Short Ram intakes install easily under the hood.
  • BlingLights filters dirt invisible to the human eye!
  • New Open Top Design provides increased air flow and rigidity over previous closed top design!
  • BlingLights unique non-woven synthetic filter media never needs oil!
  • Less down time between cleanings and no chance of over-oiling.
  • Carbon-Black powder coated pipe.
  • Element is cleanable and is Made for Life!
  • Will not void your vehicle warranty!
  • Carbon Fiber Open Top Filter
  • Open Top Design for Increased Flow
  • Reusable Filter, No More Replacing
  • Black Ionized Stainless Metal Piping
  • Mandrel Pipe Bends for Less Restriction
  • Many Sizes In Stock
  • Rubber Collar for Secure Fit
  • Two Adjustable O-rings for Secure Fit
  • Step by Step Installation Instructions
Frequently Asked Questions
How Does It Work? When you bolt-on a BlingLights intake, you will notice the difference the next time you drive your vehicle. Our BlingLights Intake Kits are a great way and in many cases the only way to maximize airflow and engine performance. They will replace the factory air box providing both High-Flow air filter technology and a larger air filter size. This winning combination will increase horsepower and sound great too.
BlingLights Intake Kits will free your car from the size restriction that comes with the factory air box. These economical kits can take a variety of different forms based on vehicle characteristics and available space under the hood. Each kit is designed to provide power throughout the RPM range. BlingLights intakes take advantage of the added airflow provided by an oversized air filter released from the restrictive factory air box.
These kits bring engine airflow out of the factory box by providing a large size open-air conical High-Flow Air Filter. The extra surface area of these open-air air filters provide even more airflow at lower restriction than a name brand replacement filter which is always limited to the size of the factory air box. The larger air filter also captures and holds more dirt increasing its service life before a cleaning is required. The filter is then either directly attached to the engine carburetor or throttle body or indirectly through a tube assembly running from the filter to the engine. All adaptors are made from high quality materials.Why Does The Factory Intake Need to be Improved? Most people are aware that our High-Flow Air Filter can increase horsepower over a traditional disposable air filter. An air filter change alone however, cannot eliminate other types of air restriction built into the vehicle at the factory. These can be found in the size of the air box and the air path running from the air box to the engine. That’s where air intakes rule the road. They completely replace the factory airflow assembly including the filter, air box and air path. More and more people are discovering the monster power available from a well-engineered air intake, so go ahead and wake the sleeping giant in your car.
How Do You Know It Works?We will not sell an air intake that does not provide a measured increase in horsepower and torque (acceleration). Our air intakes are proven to increase horsepower and torque on a rear-wheel dynamometer (think treadmill for cars). These thoroughly engineered air intakes provide huge increases in power that a customer will definitely feel when they accelerate. BlingLights is known to prove performance!
How Much of an Increase in Miles Per Gallon Should I see from using a BlingLights Intake?Results will vary depending on your vehicle, driving habits, load on the engine (towing for example), existing air system restriction, and other factors. Many BlingLights users report an increase in miles per gallon. If you take advantage of added power by driving harder, you will not see much of a gain, if any, in MPG.
Can I Install and Maintain the Intake Myself?The kit isn't complicated too install for most applications, and the work can be done in your driveway with simple hand tools in about an hour. We recommend to have the kit installed at stereo shop if you are uncomfortable installing on your own. If you do it yourself, you will need a wrench, a ratchet, and a screwdriver. Every 50,000 miles clean the filter with filter cleaner found at your local auto shop. No need to ever replace the filter.
Is the BlingLights Intake Street Legal?In most states our intakes are legal. Our intake kits may not be legal in states where under the hood modifications are not allowed. Check your local laws if you are unsure.
Will the BlingLights Intake Cause My Vehicle Mass Air Sensor to Fail? No, it is both impossible and ridiculous. An engine can only take in a fixed volume of air depending on the engine’s size. The more restriction that an air intake system (filter, air box, and tubing) causes, the greater the potential is for power and mileage degradation.
Will the BlingLights Intake Void the Factory Warranty?NO. The only time this can happen is from improper installation that causes damage to a vehicle system. If a service technician denies your warranty claim ONLY because the car is modified with an Blinglights intake system and the vehicle system failure was not a direct result of the installation and use of an Blinglights intake, please refer him to the Magnusson Moss Warranty act. You can download the Magnusson Moss Warranty act from SEMA’s website at: http://www.enjoythedrive.com/san.
All Mount Accessories Included, Quick Replacement & Easy To Install.
(MAF Sensor Adapter not included. This is required for some vehicles)
Will Fit Most Domestic & Import Vehicles From Race Cars,
Street Cars, SUVs, Trucks and Vans
MCF Member's `What do you think of above.
Post & let Anthony know : )
$62.00 ? ?
Old Jun 29, 2009 | 07:46 AM
Hot air intake- it'll suck in the hot engine bay air from near the exhaust crossover pipe, and from the radiator fan wash. I'd personally rather have a stock airbox with adrop in K&N than a HAI. Better yet, I'd buy/build a true CAI box or FWI.
The problem with those setups is your flow restriction goes down, but your intake temps go way up- so you kinda end up shooting yourself in the foot.
Old Jun 29, 2009 | 07:56 AM
I agree. I wouldn't go with that over a wiz-aired.
To keep costs down, do it yourself. Or buy the kit properly or you'll be hurting more than helping.
Old Jun 29, 2009 | 12:28 PM
atg284's Avatar
Yeah, I was kind of thinking that it would be something only for looks....
Soo I went for the K&N FIPK
Thanks for your help I trust your judgment
Also, thanks KidSpace for extrapolating the data from the link
Old Jun 29, 2009 | 12:56 PM
Again the K&N isn't the GREATEST, but it's better than that and IMO looks the best.
Hope you are happy with the product. It was a breeze to install in the wintertime for me.
Mr.Monte
Aug 31, 2012 07:55 PM
BlackRainSS
Feb 4, 2012 04:09 AM
The Popcorn King
Aug 21, 2009 09:34 PM
roadshoptuner
Aug 4, 2006 07:32 PM
big green dog
Apr 24, 2006 05:25 AM
