Uh-oh
Old Apr 11, 2014 | 05:06 PM
ecosta221's Avatar
Default Uh-oh
Ok so i have a problem now. I snapped one of the rear crossover pipe studs. The top one for the heat shield. I need to know what size stud it is so i can get a new one but EVERYWHERE i look i cant find it. Does anyone have any idea? Im trying to get it removed and fixed tomorrow but i dont have the bolt or the size. Pleaseeeee help.
Old Apr 11, 2014 | 06:33 PM
I used a torch to heat up the broken stud on mine then I replaced the stud with a bolt .. I have no problem with it.. A bolt works fine..
Old Apr 11, 2014 | 09:36 PM
ecosta221's Avatar
What about the heat shield tho? How did you get that on?
Old Apr 12, 2014 | 12:33 AM
Habbibie's Avatar
Keep it off, mine is been off for 10 years, never had a problem!
Old Apr 12, 2014 | 06:46 AM
03SSLE's Avatar
If there is enough of the stud protruding you might get it out with penetrating oil, heat and a vice grip. If it snapped off flush you'll need to drill it out then use an easy-out and penetrating oil to remove it. Any hardware store should have a replacement stud, or you can order it through a Chevy dealer.
