Time for a New Cat
Old Jun 22, 2011 | 06:19 PM
03SSLE's Avatar
FYI - If the car DOES throw that P0420 code, a trick I was looking into when i first put a high flow cat on my Monte was a spark plug anti-fouler. The concept is to space the O2 sensor out of the main exhaust stream, reducing what exactly it receives for readings. I've read people with multiple different drive trains that claim success using that trick...since I had my PCM tuned, I had that code deleted from it at that time.
Thanks for the tip. Those anti-foulers are only a couple of bucks so I'll probably just put one on it from the get go and be done with it. I don't know if I could get away with having the sensor deleted from the PCM or not. From what I understand about the smog check around here they look to see that all the sensors have run their self-diagnosis, and if one comes back that hasn't run you fail the test. The anti-fouler trick is cheap and a lot less hassle.
Old Jun 22, 2011 | 06:43 PM
The PCM doesn't even know the code anymore, so it will NEVER return on that scan.
04 dale jr supercharged
Nov 12, 2011 05:57 AM
warriormagee
Jul 11, 2011 02:05 PM
BocaReject
Apr 13, 2011 07:36 PM
kicker
Apr 2, 2011 09:41 AM
Dave McFly
May 11, 2008 08:28 AM
