Summit Fully Welded Mufflers
#42
I am thinking of doing this to my 06 3.9 any better suggestions???
MPE-35125
Exhaust Tip, Stainless, Polished, Straight/Rolled Edge, 2.25 in. Inlet, 3.5 in. Outlet, 4.5 in. Long, Each
SUM-638221
Muffler, Chambered, 2.25 in. Inlet, 2.25 in. Outlet, Offset Inlet, Center Outlet, Steel, Aluminized, Each
MPE-35125
- $34.81
- 2
- $69.62
SUM-638221
- $29.95
- 2
- $59.90
#44
Chris,
Find out what kind of stainless those tips are made out of (hopefully 304) and the mufflers are going to be aluminized, which means you may want to paint them (find stainless ones), or something because they will rust through in a PA winter.
#45
Yes, like I did, get high temp spray paint and make sure to spray these mufflers before getting them installed. You'll also want to spray the welds too. Most shops should do this for you though while it's in the air.
If they make high temp clear coat too, it wouldn't hurt either.
FYI, I did 3 coats on each and it's already starting to peel and look bad-ish around the edges.
#46
#47
Well if it's the same diameter pipe as the SS, which I believe it is they're in-fact 2.25.
Here's a link to the mufflers I bought.
http://www.summitracing.com/parts/SUM-638221/
#49
#50
I honestly have NO idea what a turbo muffler entails that would make it different than a regular baffled muffler. I'm assuming it has something to do with the inner workings of it, but couldn't really tell you.
