6th Gen ('00-'05): Should I get a ZZP Downpipe?
Old Aug 5, 2014 | 12:05 PM
turbo monte's Avatar
2 on the rear manifold where the downpipe meets the manifold and 2 under the car just after the cat.
Old Aug 5, 2014 | 12:55 PM
afterburner34's Avatar
So does the ZZP downpipe come with new gaskets or is that seperate bu? Also would I need an O2 Bung extenison?
Old Aug 5, 2014 | 01:05 PM
Should come with new gaskets. The extension harness I'm not sure about because I'm no longer using a rear o2 sensor.
If you put a aftermarket downpipe with high flow cat it will throw a engine light for rear o2 unless you have that code tuned out of your pcm just so your aware of this.
Old Aug 5, 2014 | 01:07 PM
Yes im aware that the SES light will come on but I can easil get that code deleted. I just dont want to get my old pipe off and not be able to complete the new one because I dont have every necessary part to go with it
Old Aug 5, 2014 | 01:10 PM
If your getting the code deleted from the pcm you don't even need the rear o2 hooked up then.
Old Aug 5, 2014 | 01:11 PM
The Pipe comes with O2 Bung to place it so I dont want an open hole in it
Old Aug 5, 2014 | 01:17 PM
Also I see that people who remove the O2 sensor get worse MPG. Would this still happen if I delete the code? Or would it be better to leave the O2 sensor
Old Aug 5, 2014 | 01:46 PM
What do you guys recomend the 2.5" with cat or 3". My car is supercharged but I dont plan on doing many more engine mods to it
Old Aug 5, 2014 | 01:50 PM
If you don't plan on going crazy, a 2.5 will be fine for you. Your MPGs shouldn't change, unless your right foot does
Old Aug 5, 2014 | 01:57 PM
Well if I were to just add the downpipe will the 3" perform better or worse? Just want to get the best option for my vehicle. So Pros and Cons to each?
