Powerlog Question
Old Jun 5, 2013 | 11:29 AM
dan1313's Avatar
Default Powerlog Question
Anyone have suggestions for qwhere to get a powerlog from for a l67? I know zzp has them but they arent in stock and wont be for around a month they said so iw as wondering if anyone else has a good review from a different company
Old Jun 5, 2013 | 05:31 PM
The Power Log is only made and sold by ZZP. Aside from that, you can look into headers. My best recommendation, shoot ZZP an e-mail. I ran into the same issue when I was looking for mine. They might be able to provide some info on when they might have more in stock.
Old Jun 5, 2013 | 06:27 PM
I know they make them in batches. I would definitely ask, you don't really want to go used on those, because you MAY get an older stock which is prone to cracking.
Old Jun 5, 2013 | 06:48 PM
I bought a used powerlog & a ceramic coated crossover pipe for $100 ,
I had no problem with both..
Old Jun 5, 2013 | 09:13 PM
nitehawkjcb's Avatar
You've been lucky. Earlier designs of the plog liked to crack where the primaries met the rest of the plog. Sounds like you got a deal.
Old Jun 5, 2013 | 09:17 PM
Thank's but if it cracked a friend of mine owns a welding company so he could weld it for me if needed..
He welded the sub-frame on my 1940 chevy..
Old Jun 5, 2013 | 10:21 PM
My PLOGS did crack and a very small particle of the failed weld went out the exhaust side of my turbo.... Front and back ones, cracked where the cylinder pipes were welded going into the collector. Major repair ongoing because of that. They are only rated to 300 hp also, after that ZZP recommends headers. I had Cartuning make new exhaust manifolds good for over 600 WHP. I would hesitate to trust even the NEW ones if your boosted.
Old Jun 6, 2013 | 11:12 AM
dan1313's Avatar
Alright Ill try that out. thanks for the help guys
schroederchevelle
17
Apr 19, 2015 06:21 PM
Barnacle14
Feb 19, 2014 11:29 PM
04IntimidatorSS
May 12, 2012 12:45 AM
shingding88
Dec 14, 2009 08:35 AM
Submariner
May 31, 2008 09:39 AM
