6th Gen ('00-'05): New headers, and exhaust layout?
Old Jul 21, 2014 | 06:44 PM
Floydcarlo's Avatar
Default New headers, and exhaust layout?
Hi All.
I will be replacing my manifolds with TOG and maybe magnaflow mufflers, but will consider something that is deeper sounding. Money isn't really the problem.
The Other Guys Exhaust Headers: 3800 Performance
I will be possibly be getting rid of the catalytic converter and putting in a test pipe in. But in all actually I just want true dual exhaust, but is this possible with the 6th generation and this kit? If it is possible what layout would I do? Ive read a back pressure is needed for correct torque and heard short headers burn up cats. I know that it is easiest to put a high flow catalytic converter on but I want her to sound deep and breathe as easily as possible.
Thank you for your time and input.
Old Jul 21, 2014 | 07:22 PM
HIxArsenaL's Avatar
Sorry i cant help a whole lot, but for my exhaust system i did a resonator delete and i have a camaro catback system w/ dual exhaust tips...it sounds pretty deep and loud no doubt!
Old Jul 21, 2014 | 07:27 PM
TOGs still collect into a single downpipe, then Y-pipe out to 2 mufflers. Not a true dual, and I have heard a few complaints about drone with the set up.
Keep in mind this set-up will throw a CEL, and if you have emissions in your area, you can fail. Unless you have a tune to remove the P0420 code.
Old Jul 21, 2014 | 07:33 PM
Floydcarlo's Avatar
I see that they have a inlet pipe,I was thinking of welding a piece of stainless on it and have the other piece go sepereate. I have no emissions check, electrical tape covers the cel lol. What were the complaints? Were they the same ones a few years ago about TOG? I read about SLP but heard they hang lower than the average headers.
Old Jul 21, 2014 | 07:35 PM
Floydcarlo's Avatar
I thought about the dual exhaust tips, but I have the factory ground effects. Would they work okay?
Old Jul 21, 2014 | 08:24 PM
Not sure I'm following how you want to put it together? The TOG set up, has the front 3 collectors go into the crossover, the crossover goes into the rear collector section, and that all funnels into the downpipe which connects to the stock cat-back. I think you'll have to do a good amount of cutting and welding to have the crossover be the second exhaust, that it wouldn't even be worth starting with TOGs.
I don't believe the TOG system drops too low where you have to worry about the downpipe like the SLP.
The complaints were drone and sound. Too loud on the highway and what-not.
And don't just electrical tape the CEL, it's a good light to actually have. Just look into the PCM tuning since money wasn't an issue to start
Old Jul 21, 2014 | 09:01 PM
Mac7504's Avatar
What about the SLP headers? I run a set and don't have any issues...Some have had issues with the header contacting the sway bar when getting into reverse (harder than norm) but that could easily be fixed by flipping the bar. I have no issues with the SLP's in my car, fwiw.
Or just get an o2 emulator?
Old Jul 21, 2014 | 11:53 PM
turbo monte's Avatar
It is near impossible to make a true dual setup on a front wheel drive car because the front manifold will always be longer than the rear and never be equal length.
Also you can get a deep idle but with this as stated highway drone is bad and it's raspy in high rpms. The 3800 will never sound like a v8.
cmb66
Apr 21, 2015 07:13 PM
02CHEVYMONTESS
Nov 11, 2012 04:13 PM
blackmonte781
Jun 4, 2012 08:44 PM
mcarloss04
Dec 18, 2006 07:58 AM
zapp59
Aug 1, 2006 02:46 PM
