Just installed Super 44's
Finally decided to install some mufflers and judging by Youtube the 44's were the way to go. The bad thing is that they are not loud enough, At start-up they sound great, almost v8-ish then it mellows out where the rad fan can drone it out. Iv'e been reading that there might be a "break-in" period so that's what I'm hoping now.
I haven't driven it far enough to heat them up but after a quick trip they do tend to be a bit louder.
My only other option is to remove the resonator and see if that helps out. I'll try to post up a vid tomorrow.
Flowmasters aren't supposed to 'break in' because it's all metal on the inside, not fiberglass like others.
You should look into the SLP Loudmouth II's, they're loud and similar sound to Flowmasters at idle.
