intake
Old Sep 15, 2005 | 11:20 PM
mcarloss04's Avatar
Default intake
does an aftermarket intake void the warranty
Old Sep 16, 2005 | 01:01 AM
04MonteLS's Avatar
Default RE: intake
ORIGINAL: mcarloss04
not by default...if the dealer were to deny a warranty claim for that, they'd have to prove that's the cause of whatever problem there is with the car.
Old Oct 13, 2005 | 04:28 PM
mickey's Avatar
Default RE: intake
where did you find a after market intake for the car?
I have been looking for one for the 3800 for a while Would rather get rid of the one they claim likes to leak.
Old Oct 14, 2005 | 10:15 AM
montejass's Avatar
Default RE: intake
The problems with the current leakage issues revolves around the gaskets and not so much the intake itself.
GM has been using crappy cheap gaskets for quite some time now... The interaction of bad Dexcool just enhances the gasket problems.
Old Oct 14, 2005 | 04:30 PM
mickey's Avatar
Default RE: intake
so wha tyour telling me is i replace the intake gaskets on my car it will solve this issue?
If this is the case i can do that in a afternoon with alot of time to spare.
And they have to be cheaper then a new intake man.
Old Oct 26, 2005 | 11:01 PM
z34phoenix's Avatar
Default RE: intake
you car confusing intakes with the intake manifold. the leak is around the lower intake manifold. there are few replacements for that. unless you buy a port and polish one. the intake that you are thinking of are new intake tubes to relocate the air source for the engine. either a fender well intake or some other type of cold air intake. some just drop the filter low to the ground-which is bad due to water and dirt.
for the average do it your selfer, redoing the lower gaskets is pretty difficult. i know it takes from 3-6 hours of for the work on a DOHC 3.4 monte. but the 3100 and 3800 take longer cause you have to pull the heads if i remember correctly. i would suggest checking out 60degreev6.com ; mymonte.com ; w-body.com ; or clubgp.com for more info on this.
Old Oct 27, 2005 | 04:21 AM
mickey's Avatar
Default RE: intake
kool 5thanks for the links, also i have been wrenching for a few years now so i would not say im a ro but im a biut more thne the DIY that would do a head ligfht and be done with it LOL
but again thanks for the headfs up
seanpeezy
Jan 10, 2016 04:05 PM
augi
FWD Tech Guides '95-'07
Mar 25, 2012 12:17 PM
big green dog
14
May 30, 2005 06:42 PM
04MonteLS
May 29, 2005 12:35 AM
montejass
May 26, 2005 04:04 AM
