I cant get exhaust tips off
Old Apr 18, 2013 | 07:38 PM
TMoney's Avatar
Default I cant get exhaust tips off
Recently bought some stock SS exhaust tips off craigslist, but when the guy gave them to me, he could not get the tips off the old exhaust pipe, so he just cut the end of the pipe. Now I cant get the tips off the cut pipe. Anyone know how I can get these off? They are stuck on REALLY good. I dont want to heat it up because it will discolor the chrome
Old Apr 18, 2013 | 07:49 PM
An air hammer with a muffler/exhaust bit..
Old Apr 18, 2013 | 08:49 PM
WD40 and let em set awhile, had to do it with mine
Old Apr 18, 2013 | 09:24 PM
Enzo354's Avatar
STILL SLOW
Those suckers get stuck on there pretty bad. An air hammer could really mess them up though.
Old Apr 18, 2013 | 09:33 PM
TMoney's Avatar
Did they just knock right off after that?
Old Apr 19, 2013 | 08:11 AM
I have used a small chisel,or screw driver...
and pryed the pipe away from the edges inside the tip...
Only enuff to free it and slid it right out... (Deforming the rusted pipe inside the tip) As long as your careful enuff to not deform the tip.
The rusted pipe will have a tendancy to give before the tip will deform...(Old School)
Old Apr 20, 2013 | 05:54 PM
Pb blaster is a little more powerful than wd40. I would try that to break the rust down
Old Apr 20, 2013 | 08:38 PM
nitehawkjcb's Avatar
I'd use PB Blaster or Liquid Wrench to loosen
Old May 8, 2013 | 08:32 PM
TMoney's Avatar
They are still stuck anyone else got any other ideas?
Old May 8, 2013 | 11:11 PM
Mike 00LS's Avatar
I'd get out a small flat screwdriver to punch in a small piece of the pipe, so you can get something between the pipe and the tip to work your way around it.
