6th Gen ('00-'05): Gas Smell
Old Mar 31, 2015 | 11:55 PM
Gproducktionz614's Avatar
Default Gas Smell
Hey my 2005 Chevy Monte Carlo LS has a strong gas oder whenever it idles or when the heat is turned on, now I was told upon purchase that there is a small exhaust leak, could this be the cause of the smell?
Old Apr 1, 2015 | 12:03 AM
I would get to the bottom of this, sounds like you have an actual fuel leak, and then "Poof". Follow all your fuel lines, could be that a rear injector O-ring is failing, something close to the heater air intake. If anything have a shop search it out, if for some reason you can't find it, this could get ugly on a very hot day... poof poof poof
Old Apr 1, 2015 | 01:01 AM
Default Exhaust Hole
Would the small hole that was told to me be the cause? I have a catalyst converter code or O2 sensor.
Old Apr 1, 2015 | 01:41 AM
JC Colon's Avatar
Exhaust gas and Gas Fumes smell completely different. If you smell Gas you have a Fuel leak. Check your fuel lines against the fire wall under the Master Cylinder. The connection were they go from a solid line to plastic. The connector there wares out on the pressure line. Also check the plastic line the crosses over the engine to the fuel rail and the connector at the fuel rail. These are your greatest weak points.
I had a leak at the connector under the Master cylinder. The intake for your heat is right above that. So if the leak is there, that would explain the fuel smell I'm the car when your heat is on.
At any rate, you should have it checked out ASAP, because if it's over the engine it could start a Fire, then you baby goes "Up In Smoke!"
Old Apr 1, 2015 | 09:32 AM
nitehawkjcb's Avatar
^Not necessarily.
Evap leaks smell like gas. So does running rich...
Old Apr 1, 2015 | 11:47 AM
JC Colon's Avatar
Good point John! I didn't think about that. The Evaps canister is in that same area! I've never had a Rich mix in a fuel injected engine but yeah, I remember in a carbonated engine the fuel small did get into the cabin! Nice catch!!!!!
Old Apr 4, 2015 | 01:47 AM
Still haven't diagnosed the initial problem but I appreciate you guys, just fixed my actual exaust leak/shaky hanger. The gas smell isn't as bad but still present.
Old Apr 4, 2015 | 02:33 AM
02ssintimidator's Avatar
Probably evap. Is the engine light on?
Old Apr 4, 2015 | 09:38 AM
Malcolm Fay's Avatar
My 2000 had a fuel leak at the rear fuel rail disconnect strong odor took a little longer cranking to start (low pressure) found a neat repair kit. Enter Malcolm Fay in search box read my post on fuel leak repair for details on the kit.
Old Apr 10, 2015 | 12:18 AM
@02ssintimidator, engine light is on!
