Finally looking into headers...
Old Jan 13, 2011 | 08:05 PM
  #31
A few comments here- I have the DPP headers which are virtually the same as the SSAC's and the rest of the SLP knockoffs.
First- if you're worried about a true show quality finish- I'd consider having the headers coated. There are many nice coatings which look chrome-ish, and they tend to hold their look better as long as you keep them clean (ie not dropping oil on them and letting it burn). As the headers sit- they won't look as pretty as the pictures for even a couple days. I got the usual header discoloration after the first couple drives- but after months and months, they don't look that great. My header flanges have developed a good bit of surface rust (not sure if they're mild steel or just a crappy stainless grade)- and the headers themselves are very discolored. I realize you can buff them back again- but that is much harder said than done when they're in the car- getting in between all the piping and such.
Secondly- I wouldn't say you must lose AC- a lot of people have installed headers without losing AC. I'm sure it varies a lot depending which headers you get- since they seem to be truly all over the place. However, the fact that this is a pretty labor-intensive install is pretty spot on. You're working in tight areas- and dealing with the ebay headers- you don't really know what you're gonna get- especially if you try a lesser known brand. I've seen people have to cut the headers up and have parts rewelded, etc to fit.
Third- I'd definitely avoid the Pacesetter design (those like the first link)- they are easiest to spot by having each set of cylinder banks come down into its own tube with a short Y pipe to combine them. Even the much more expensive 'real' Pacesetters had a problem leaking here due to sloppy manufacturing tolerances in this area leaving too much gap. Granted the latest ones are supposedly fixed- but I wouldn't trust the ebay knockoffs to seal if even the original designers didn't get it right.
Fourth- you're talking you want 300-400 (I'm assuming wheel horsepower since we really can't measure crank horsepower easily on these cars?)- if that's the case, I'd definitely seriously consider a turbo. I know they aren't quite as pretty under the hood due to all the plumbing- but some chrome plated or polished aluminum intake plumbing and ceramic coated exhaust plumbing makes them look decent- and you'll be able to hit your power goals much much easier. Even if you're talking crank hp- 400 at the crank is a good bit with an M90- and you're going to need a good deal of mods to hit that.
Lastly- about the cat- if those Speed Daddy's come like my DPP's, they would bolt in without a cat as-is (they had a 'test pipe' that bridged the gap from the downpipe outlet to the catback. You'd have to install them, and drive to an exhaust shop to get a cat welded in (just bolt the headers on up to the big circular Vband connection) and drive open downpipe to the exhaust shop.
That brings me to one other point- one thing I do like about that design is that you can just undo a single, easy V band clamp at the downpipe bottom, and you can drop the entire catback in one shot (including the cat if you have one installed)- great for the track.
Old Jan 15, 2011 | 01:28 AM
  #32
Chevy Commando's Avatar
From what I have heard...Speed Daddy headers are not a bad header for the price even with the above mentioned problems. And yes stay away from pacesetter or their knockoffs.
As for mufflers...dynomax. That is just my personal opinion.
paintballerr78
Sep 9, 2009 05:31 PM
silver1
Mar 3, 2009 11:00 AM
88montessman
Feb 26, 2009 06:37 AM
vita
Apr 15, 2008 05:28 PM
heart slows down
Dec 23, 2005 06:54 PM
