Fender-well intake good? bad? both?
Old May 4, 2011 | 08:52 PM
03SSChevyFun's Avatar
Question Fender-well intake good? bad? both?
I have a Spectre CAI air filter on my monte (but it's more of a "WAI" right now) which is why im thinking of going the route of extending it into the fender...but ive heard mixed opinions about this and i really want to settle it once and for all.
i know that fend. well intakes are very good cuz the air is nice and cool down there, but the other argument i keep hearing (and i believe is a legit concern) is that the air filter gets wet down inside there when it rains which is bad for the engine apparently.
can anyone help shed some light on this subject? im at wits end here...
Old May 4, 2011 | 09:39 PM
jwjones's Avatar
There should be no reason your filter should get wet from water. As long as you have your wheel well covers then your okay. Wheel well covers are there to prevent rocks, water, ect. to gain access to your motor. So to answer your question yes fender well CAI is perfectly fine. I actually had one in my 1988 mustang gt and I had no wheel well covers and drove through a flood and everything was fine.
Old May 4, 2011 | 10:05 PM
Fender well intakes are very common with our cars, as it's a cheaper option and almost as good as a cold air intake.
you can either use a flex pipe or custom bent piping into the fenderwell with that same cone you have now if it'll fit.
If you don't want to route it into the fender...You may go behind headlight opening ..
Old May 5, 2011 | 04:21 PM
Enzo354's Avatar
STILL SLOW
I had mine way down in the fender, no issues with water. Its not like water can go up the tube either. You would need 2 ft deep water+ to get a vacuum effect going.
Old May 5, 2011 | 05:25 PM
thanks a lot everyone. im prolly gonna go with the flex pipe for now until i can get custom piping made. just so that it can get some cooler air, it really needs it since im gonna start racing it this summer.
Old May 5, 2011 | 06:09 PM
where do you plan on racing at?
make sure you dont leave the filter itself in the engine bay, this will only bring warm air and hurt you right after the first trip down the strip
Old May 6, 2011 | 12:59 AM
Enzo354's Avatar
STILL SLOW
Mines hot air right now though. I honestly cant tell the difference.
Old May 6, 2011 | 06:45 AM
gothkid's Avatar
These guys call my intake a hot air but i think it does alright, me and a friend of mine noticed a huge performance increase. To top that off might be doing a one off custom ram air good using a steel cowl.
Old May 6, 2011 | 06:50 AM
It's hard to FEEL the difference of a HAI since your throttle response is improved so you "feel" performance. But throttle response ≠ denser air and a better air/fuel ratio
