Exposing ECM
Well, I was concerned so I went to my favorite junkyard, Pick 'n Pull. There I found a late 90's Monte, with a near perfect ECM box bolted to the passenger side fender. After a very slight modification (cut off one angled corner), all I had to do was drill a new mounting hole to use it to mount and secure my ECM. The only other change is that the harness doesn't get routed through the normal plastic conduit, but rather a preexisting hole once 2 staples are removed allowing the top half of the box to become "hinged". There is also an nifty plastic hose with an air duct at it's end to help force cooling air into the box. With it bolted to the frame, directly under my CAI it's hard to tell it didn't come on this car.
gonsailin
Dec 3, 2007 03:40 PM
