Exhaust leak
So my temp sensor went bad and the only way to get to it is to remove the crossover pipe. while doing this i got all but one bolt out. the last one snapped. after i got everything back together, i now have another problem.
The loudest annoying exhaust leak ever. my question is how can i fix it without ripping everything apart? The way it sits now it is impossible to fix. there is no room at all. if i got another bolt i wouldn't be able to hold the back side of it to tighten it.
Any ideas?
Any ideas?
well i finally decided to try and fix it today and the only thing i did was make it worse. I tried takin the other bolt off and who would of knew. It snapped right off. I tried everything and the only way it seems possible is to pull the motor.
This SUCKSSSSS
This SUCKSSSSS
So what you're saying is two bolts that attached the crossover to the back exhaust manifold snapped off?
Just remove the rear exhaust manifold (the bolts will be fairly tough to remove), unbolt the downpipe, unbolt the crossover from the front manifold. Remove the rear manifold & crossover, then you'll need to drill out the broken bolts (if they're still in the manifold). If they're not in the manifold, you just need two new bolts.
Maybe you can remove the downpipe and drop the rear manifold with the crossover out the bottom?
