exhaust
Old Nov 11, 2007 | 06:58 PM
03SS's Avatar
Default exhaust
How many mufflers are you guys running? I want to just run one muffler where the resonator is now, is this possible? Will a muffler fit in the space where the resonator is? The reason I want to do this is because you can see the two stock mufflers hanging up under the car and It doesnt lookall that great. Also what muffler do you guys reccomend? I want a nice deep smooth tone. Not choppy at all, just deep and smooth.
Thanks in advance,
Steven
Old Nov 11, 2007 | 07:05 PM
scc24540's Avatar
Default RE: exhaust
ORIGINAL: 03SS
Thanks in advance,
Steven
the resonator is behind the left rear tire and it would be near impossible to run a muffler there. and i suggest either a flowmaster super 44 or a 80 series. all depends on your taste, they have clips on youtube of what our cars with all these mufflers sound like for further advice. what i did was right past the cat i ran 1 super 44 and side exit after that, a muffler will fit there. hope this helps
Old Nov 11, 2007 | 07:20 PM
04 Intimidator's Avatar
Default RE: exhaust
X2. You won't get the best sounds because 6 cyl still don't sound like 8's, but they can be much better.
Old Nov 12, 2007 | 12:13 AM
z34phoenix's Avatar
Default RE: exhaust
WHAT?
there is plenty of space under the car for a single muffler. i run a single magnaflow muffler under the car just after the cat, a glass pack where the res by the tire was and then a Y and dual pipes.
sounds nice and deep. no rasp, single was cheeper and lighter... best of both worlds
Old Nov 12, 2007 | 07:07 PM
scc24540's Avatar
Default RE: exhaust
ORIGINAL: z34phoenix
WHAT?
whats the what for? i agreed it was room there but i said there isnt room to place the muffler where the resonator used to be. the setup i have now has the si/do right after the cat then side exit. but remember it is a 6 cylinder it wont sound as good as a v8 but dont get me wrong it will sound pretty sweet
Old Nov 15, 2007 | 09:22 PM
03SS's Avatar
Default RE: exhaust
Yeah, I just dont want the two mufflers visable like they are now. So anywhere under the car would be good.
Old Nov 15, 2007 | 10:39 PM
lav74's Avatar
Default RE: exhaust
I run 3" from the headers to the Y before the gas tank. My split doesn't happen after the gas tank anymore. It evens the flow out a bit better.
Also, if you go in the sights and sounds section, you can see my setup, but it's a little dark. What I have now is a 30" long, 3" in/out, and 6" round magnaflow res/muffler right after my cat. I have no rasp, and the rumble is deep. Every person that I've asked so far does not believe it's a 6 cyl. They think it's a V8 on steroids.
Old Nov 19, 2007 | 06:22 PM
bigmanx's Avatar
Default RE: exhaust
I just got my exhaust installed and sounds great. I got 2.5" pipe from the cat to the Y split, no resonaterand dual 40 flowmasters. If you want great sound get it done that way Ill put up vids when I get a chance.
Old Nov 21, 2007 | 02:04 AM
nix06monte's Avatar
Default RE: exhaust
^ X2
Thats what i got sounds sweet
cmb66
Apr 21, 2015 07:13 PM
