Drawbacks of no back pressure?
Old Aug 20, 2008 | 05:18 PM
mbusboom10's Avatar
Default Drawbacks of no back pressure?
Can anybody explain the theories behind back pressure?
I have the understanding that back pressure means absolutely nothing to engine performance.. I think of it as a misused term for slowing down the exhaust gasses so that the pulses can line up enough for scavenging to come into effect (leading end of pulse is very high pressure and trailing edge very low pressure.. if the trailing edge is close enough to the leading edge of the next pulse then it will cause a pulling effect). If there is unrestricted flow does that mean that at low RPM's the pulses are too far apart from each other for scavenging to come into play.. while at high RPM's they are? If true, then it would mean that restricting flow would keep the pulses closer together at low RPM's but making it much harder on the engine to expel the exhaust at higher RPM's right?
Old Aug 20, 2008 | 07:52 PM
2000_BLACK_SS's Avatar
Default RE: Drawbacks of no back pressure?
i have no clue what you are talking about pulses. but the way i was told about pressure is that if you have to much it hurts your mid to top end power and if you dont have enough then you will have no low end torque. thats what i was told
Old Aug 20, 2008 | 08:19 PM
odessadude's Avatar
What's the old saying? Big blocks use small header small blocks use big headers?
joe111599
Jun 10, 2016 07:01 PM
sal23
Jul 9, 2013 05:46 AM
Randy Biron
Jul 14, 2012 08:07 PM
mavrickf1613
Apr 9, 2009 09:12 PM
mad717
Mar 19, 2008 06:39 AM
