Dodge exhaust tips? O.o;;
I was wondering if we could mod out exhaust tips to the square ones found on either chargers or challengers? Imo that would be cool looking, ofcourse the bumper would need to be modded though, thats no problem with a body shop...
BUT, is it possible?
Mopar exhaust tips on a GM? Unless you plan on installing an Anonylizer in the exhaust system it can't be done. The Mopar tips won't be recognized by the GM exhaust pipes and it will cause all kinds of drivability problems.
J/K
As Mike mentioned as long as the inlet diameter is correct you can use any tip you'd like - no matter the manufacturer.
J/KAs Mike mentioned as long as the inlet diameter is correct you can use any tip you'd like - no matter the manufacturer.
I'm been looking at some Acura and BMW tips to put on mine. I still haven't decided for sure which I want to go with. My luck I'll buy them, weld them on then see some I like better!
Yep, just make sure the tips are the correct inlet diameter. Cut the old ones off, weld or clamp the new ones on and you're good to go.
As far as modifying the bumper cover to accommodate the new size...well...have fun!
motivation2k3
Jul 25, 2007 08:36 PM
