Dodge exhaust tips? O.o;;
I was wondering if we could mod out exhaust tips to the square ones found on either chargers or challengers? Imo that would be cool looking, ofcourse the bumper would need to be modded though, thats no problem with a body shop...
BUT, is it possible? |
As long as the tips inlet is the same size as your current pipe you could use them. I'm sure there are aftermarket versions that you can get in varying inlet diameters to make fit even easier.
I'll have to stop by the muffler shop to see...and see what I can do. I like those and i think theyll be unique.
Mopar exhaust tips on a GM? Unless you plan on installing an Anonylizer in the exhaust system it can't be done. The Mopar tips won't be recognized by the GM exhaust pipes and it will cause all kinds of drivability problems.
:wtf: :rotfl: J/K As Mike mentioned as long as the inlet diameter is correct you can use any tip you'd like - no matter the manufacturer. ;) |
Bah you....lol had my thinking like Oh no! Ahahah...now to find tips..-_______-;
Originally Posted by Hiroska
(Post 551641)
I'm been looking at some Acura and BMW tips to put on mine. I still haven't decided for sure which I want to go with. My luck I'll buy them, weld them on then see some I like better! :rolleyes: |
So its pretty much just a swap out? Nothing to do with like the cat or anything like that? I wonder how do I change my bumper around to work with it..lol @_@
Yep, just make sure the tips are the correct inlet diameter. Cut the old ones off, weld or clamp the new ones on and you're good to go. :thumbsup:
As far as modifying the bumper cover to accommodate the new size...well...have fun! ;) |
