7th Gen ('06-'07): custom exhaust/ piping / mufflers
yes itll set off a cel. you can have it tuned out, or i guess another option would be to have a o2 sensor bung drilled and welded into the catless dp(if not already there) and run a spark plug antifouler on it. you can find it in the help section of just about every parts store. there are right ups on here and tech about how to do it. simple and from what ive read effective. that would be the first thing i would try. if it doesnt work then tune it out. after that downpipe you may want a tune regardless.
there are 2 o2 sensors. one after the manifolds and one after the cat. the one after the cat just measures the exhaust coming through from what i understand.
ok, I got you. So let's say on the piping the OP linked. Would I need to go buy o2 bungs and have an exhaust shop put them in?
Alright, that works for me. Also if I replace the downpipe and y pipe, that will set off rear O2 codes won't it? and if so to get them tuned out, would it just be best to get a tune? or is there an easier way to tune out the codes? I plan on getting a tune anyway, but I'm just looking at all my options.
