Check engine light?
[:@]I have a 04 MC SS SC and i have a new exhaust, resonator delete, u bend delete, and a high flow catalytic converter. the muffler shop said that it was an 02 sensor so i got that put on and the next day the check engine light came back on. What should i do?
i would bitch out the shop... your O2 was never bad. when you go with a high flow Cat, it is not as good as a stock cat for emissions. so the rear o2 sensor will throw a code.
what you need is a rear O2 simulator basicly it fools the computer into thinking everything is all good. or if you buy a PCM or know someone with a tuner you can have the code removed from the computer.
04+ Monte's O2 sensor is different than previous O2 sensors. Found this out from Zoomer at ZZP.
The old sensors the simulators would take care of just registered that O2 was good. The new sensors step it up and check the temperature as well. The only way to clear the code now is with a Programmer as the stock PCM replacements don't clear the code, or purchase a OBD2 scanner that can clear the code - these cost between $60-$100 but in my mind are worth it as you can troubleshoot anyones car.
You can get the OBD2 scanners anywhere - Sears, Walmart, Autozone, Advanced Auto Parts, Checkers, etc.
For the programmer: www.hptuners.com and http://65.109.52.43/home_index.htm I recommend the HP Tuners one as the GUI is much better and you can use it on multiple cars not just one or one group of cars. You can use it to program Camaro's, Blazers, GTO's, etc.
hotrodharley
Nov 15, 2013 11:37 AM
