Catalytic converter question
I have a 01 MC SS with a 3.8. I know of course my rear valve cover is leaking and I'm thinking it's just dripping down on to the catalytic converter. Look under today and saw it smoking. Common for this car for the oil to leak down that far?
Leaking directly onto the cat, no. Leaking onto the rear manifold and dripping down / blowing along once it gets low enough - sure it's possible. Should be able to see either oil drip tracks or oil mist over everything down low.
I'd suggest just fixing the oil leak regardless.
If it were actually stopped up, the car wouldn't move. It may be on its way, but if it were, it should be throwing codes.
Id sooner shoot myself in the foot rather than pay someone to work on my car..
However, people overlook this issue and dont realize its a serious fire hazard..
Call a dealership tho, they might still have to do it under warranty..
My cat in my 02 SS plugged up so bad the exhaust was blowing through the stove pipe right behind the throttle body and it burned a hole though the plastic intake. I was lucky too as it was right under the fuel line for the rear fuel rail.
Valve cover gaskets aren't hard to do if you have some basic tools and a couple of hours.
