blow off valves
Old Sep 14, 2005 | 06:07 PM
mcarloss04's Avatar
Default blow off valves
i have an 04 monte carlo ss and i was wondering where i can get some blow off valves and i do not have a turbo but ive heard u can get blow off valves without turbo
Old Sep 14, 2005 | 06:54 PM
Ca$$e's Avatar
Default RE: blow off valves
Do you have a Turbo?
Old Sep 14, 2005 | 07:14 PM
montejass's Avatar
What the heck does a blow off valve do anyway???
Old Sep 14, 2005 | 07:25 PM
Ca$$e's Avatar
This is from Turbosmart.com, they specialize in turbo products for numerous vehicles
To eliminate compressor surge when changing gears. Excessive back pressure is created when the throttle is closed during gear changes or deceleration, causing turbo cavitation. This is detrimental to the life of your turbocharger, however fitting a BOV will substantially improve this problem. By installing a BOV you will significantly reduce turbo spool up time. You will notice a substantial improvement in response from your turbo between gearshifts. Boost will come on earlier giving an increase in torque at lower RPM.
Old Sep 14, 2005 | 08:28 PM
montejass's Avatar
Hummmmmmmm... Maybe there is something with these valves we don't know about...... YET...
Old Sep 14, 2005 | 10:49 PM
Ca$$e's Avatar
mcarloss04, I saw your thread about the supercharger and hope you dont think you are going to incorporate a blow off valve with a supercharger, unless you were twin charging your Monte with a turbo and a supercharger and that would be very costly.
ORIGINAL: montejass
You need a tubo kit in order to have a blow off valve. The cartuning performance turbo kit they make for an n/a 3800series engine comes with one.
ultrarevvin1
Vendor for sale section
Jan 11, 2014 07:15 PM
ultrarevvin1
Jan 11, 2014 06:56 PM
ultrarevvin1
Jan 11, 2014 06:01 PM
Humble1
Sep 30, 2013 11:07 AM
Budsjlm
Oct 28, 2009 10:56 PM
