blow off valves
i have an 04 monte carlo ss and i was wondering where i can get some blow off valves and i do not have a turbo but ive heard u can get blow off valves without turbo
RE: blow off valves
Do you have a Turbo?
RE: blow off valves
What the heck does a blow off valve do anyway???
RE: blow off valves
This is from Turbosmart.com, they specialize in turbo products for numerous vehicles
To eliminate compressor surge when changing gears. Excessive back pressure is created when the throttle is closed during gear changes or deceleration, causing turbo cavitation. This is detrimental to the life of your turbocharger, however fitting a BOV will substantially improve this problem. By installing a BOV you will significantly reduce turbo spool up time. You will notice a substantial improvement in response from your turbo between gearshifts. Boost will come on earlier giving an increase in torque at lower RPM. |
RE: blow off valves
Hummmmmmmm... Maybe there is something with these valves we don't know about...... YET...
RE: blow off valves
mcarloss04, I saw your thread about the supercharger and hope you dont think you are going to incorporate a blow off valve with a supercharger, unless you were twin charging your Monte with a turbo and a supercharger and that would be very costly.
ORIGINAL: montejass Hummmmmmmm... Maybe there is something with these valves we don't know about...... YET... |
