Where do i put my jackstands?
Old Dec 29, 2012 | 12:39 PM
BlackRainSS's Avatar
Default Where do i put my jackstands?
I've got jackstands just havent put the car on em yet. It usually sits anyway and the PSI is just fine in the tires so I havent bothered to put it on stands yet. Anyway I was looking and have no clue where I'd put jack stands. Anyone got a diagram or actual photos of where they put theirs?
Old Dec 29, 2012 | 01:07 PM
03SSLE's Avatar
Have a look at post #13 of this thread...
https://montecarloforum.com/forum/ge...n-11767/page2/
Old Dec 29, 2012 | 04:07 PM
Lorenzo's Avatar
If your pinch welds are still solid then place them there, if not you can place them on the subframe underneath the car
Old Dec 29, 2012 | 08:43 PM
Read the owners manual
Old Dec 30, 2012 | 07:23 AM
You don't need to store the car on jack stands. That's with old tire technology, you can just increase the PSI a touch to account for fluctuation.
Old Dec 30, 2012 | 10:52 AM
03SSLE's Avatar
For the most part, that statement is accurate but radial tires can still develop flat spots - especially performance and low profile tires made from a soft rubber compound that contains a large amount of nylon. The good thing is that flat spots in radial tires will usually dissipate after a few miles.
Old Dec 30, 2012 | 12:05 PM
You should never store a car with the struts unloaded.... pump up the pressure of the tires to minimize the risk of flat spots and put it on carpet to absorb moisture if that's an issue.
Old Dec 30, 2012 | 05:19 PM
03SSLE's Avatar
Yep, which is why I prefer placing jack stands under the A arms and axle tube.
Old Dec 30, 2012 | 06:15 PM
Mine only has struts in the rear...so supporting mines a no brainer...
I have cartridges in the front...Which is equally a no brainer...
With a 5th gen its kinda self explanatory...
Old school we'd just use cinder blocks under the control arms of each corner...Loosen the lugs.....Let the air out of the tires....Jerk the wheels and tires off hubs...and WALLA...automatic jack stands!
Bigg J
Dec 10, 2006 11:50 PM
jeffsmonte
Oct 10, 2006 05:09 PM
SoCalSS
Oct 9, 2006 07:42 AM
monte83
Sep 12, 2006 09:51 AM
CHOWEE21
Aug 29, 2006 04:58 AM
