Wheel Hub Assembly
Old Sep 5, 2009 | 10:30 AM
orthokneepa's Avatar
Default Wheel Hub Assembly
After a little investigation I believe a bad wheel hub assembly maybe the cause of my ABS light and low tire pressue light on the dash. I looked up the parts and they arent too bad ~$110. My monte has 125k miles so im sure one or a couple maybe shot. Any idea how to check it see which one or ones are bad? I still need to get my car scanned to which ABS sensor is bad but I figured I could avoid a diagnostic fee if there was any way to tell otherwise.
Old Sep 5, 2009 | 10:46 AM
,,Please check back on your thread question, and hopefully one of our expert tech's will post a solution to your problem. I think it's best to get a scan. Also, compare your price on hub's to the below.
Member's if you have a good parts link, please post..Thanks 4 Helping a MCF Family Member....`Space
http://www.car-stuff.com/mmparts/che...rlo/wheel.html
Old Sep 5, 2009 | 02:29 PM
Gib DTD's Avatar
First question would be what year monte carlo? If its between 2001 and 2006 go here, any earlier, i cant help http://mibearings.com/Parts/CHEVROLET/MONTECARLO.html
Old Sep 5, 2009 | 05:23 PM
The ABS light code if you get it read should be able to determine which assembly it is.
Old Sep 5, 2009 | 06:08 PM
Gib DTD's Avatar
Pep boys or Auto Zone will usually give you a free scan if you ask. Or call a few local mechanics and ask them if they would scan it for you for free. It really only takes 5 minutes and should be free even from the dealership but they like to charge $100 for that 5 minutes because its all about the Benjamins.
Old Sep 6, 2009 | 12:24 PM
Ok thanks guys. I will just have to get it read and stop guessing. I was told to jack the car up and see if there was any play in the wheels when grabbing the wheel at the 12 and 6 oclock position. There was some play on both sides but a lot of play when rocking it side to side, ie the 3 and 9 oclock postion. Is it common for the rear assemblies to go bad???
Its a 2000 btw.
Old Sep 8, 2009 | 09:19 AM
I've changed two assemblies, my left front and my right rear.
So yes, it's possible for the rears to go bad too.
ChibiBlackSheep
FWD Tech Guides '95-'07
54
Oct 13, 2015 10:47 AM
VictoryRedSled
Jan 28, 2013 04:18 PM
jaygr
May 25, 2012 10:20 PM
Bait
May 14, 2011 07:36 PM
rgant_19
Aug 14, 2009 08:13 AM
