What's your mpg?
Old Jun 13, 2014 | 01:09 PM
nitehawkjcb's Avatar
16-17 in town, 26-27 on the highway. Less if I give I get heavy on the pedal more than a couple times.
Old Jun 13, 2014 | 05:12 PM
My overall average is around 20mpg. Will do 22-23mpg on the highway and probably 17-20 in town.
Old Jun 14, 2014 | 12:33 AM
My monte's gas mileage is pretty crumby. The only time I calculated it was years ago and it was in the mid-low teens in the city. I guess that's somewhat to be expected between the big cam, high stall converter and driving it rather hard. I expect it to be even worse once I get it running since I switched it over to E85. Who knows, I might end up about the same on average since I'll be doing a lot more highway driving out here in AZ.
Didn't build it for the gas mileage though. At least the vette gets decent mileage. Does a solid 30 mpg if you stay on the highways at a reasonable speed.
Old Jun 14, 2014 | 06:38 AM
butch049's Avatar
I do almost all hiway but after I put the CAI in my 3800 im getting 31-32 mpg it did go up. I also put on 65 and cruise control.
Old Jun 14, 2014 | 06:53 AM
The BudChev, with its s/c 3800, get in the range of 19-23 mpg in the city if I'm not standing on it all the time. Taking it easy on the highway, it get's about 28 mpg. All my calculation are based off converting the computer L/100km info
Old Jun 14, 2014 | 07:35 AM
Jomao_o's Avatar
17 with a mix of city and highway.
Lately I've been experiencing that if I dont roll the Windows down and turn AC on, I'm averaging 18.5 mpgs.
Old Jun 14, 2014 | 07:56 AM
Hiroska's Avatar
17 city, 24-26 highway. 07 ss, and I need tires. If I had better tires I'm sure it would go up, and also if I had a cai
Old Jun 14, 2014 | 02:59 PM
Default Check this as a rule of thumb
Originally Posted by Nightmagic11801
Just curious as to what mpg you get out of your monte? There's the said mpg the dealer's say u get...but then there is the actual mpg based on where u live, how you drive and the gas you use. Curious as to which generation got better fuel mileage too.
I need to run a full tank on the "new" engine yet to see what I get. But on my old one I got 21/22 city/back roads. And about 28 highway. I have the basic 3.4 in my 03 and I just use regular unleaded. And since I live in PA I have a lot of hills and bends to conquer.
Please share if you know your mpg. This info could help someone know if their car is getting the proper mpg as well.
mpg is a sticky subject, has a lot of variables, My 99 Monte gets about 29 miles to the gal, I get a bit more if I use regular gas instead of an ethanol blend. K-N filter helped a bit, Lucas oil fuel injector cleaner will help also. I am attaching a Photo of an Impala dash Speedometer and tach if you see this picture on your vehicle Tach below 2grand, speed about 75 you might be able to get 30 plus try it.
Old Jun 14, 2014 | 05:06 PM
iMuf's Avatar
I don't have my Monte anymore but when I did I got around 12-15MPG in the city which is what I drove most of the time. On the highway I got around 18-20MPG
Old Jun 14, 2014 | 09:09 PM
ROBF's Avatar
21 highy and city.I need to do some tuning.This car sat in a garage long time.
2003 65,000 mile.Proble needs fuel filter changed,
