What's in/on Your Monte Engine ?
Had a few things done to my engine as well:
•GM 3800 V6 block that was hot tanked and inspected before being honed with deck plates
•Fully balanced rotating assembly
•Cylinder heads flow checked for maximum air flow
•Full race port on cylinder heads by Bill Jones
•Valve seats ground on cylinder heads
•Custom Diamond 10.1 Racing pistons
•5/16 Comp Cams Chromoly push rods
•Comp Cams Pro Magnum 1.9 Mini-Shaft roller rockers
•Cometic head gaskets
•Comp Cams Magnum valve lifters
•ARP head and main studs
•H13 piston pins
•Ceramic coating for piston tops and moly coating for the sides
•Stainless steel piston rings
•Comp Cams GM38 3161 camshaft
Double Roller Chain
Cryogenically treated virgin GTP crankshaft
Camshaft / Crank shaft had military grade Calico coatings applied
Pauter Billet race X-beam rods
OEM throttle body
L26 Plenum
ZZP HV3 insert
Siemens Deka 80# injectors
ZZP billet fuel rails
Borg-Warner EFR 8374 turbocharger, integrated BOV / wastegate
ABACO 90mm digital mass air meter
Billet vacuum block
Meziere electric water pump
Modified aluminum valve covers, had to enlarge areas where the valve springs were hitting cover walls. Welded on enlarged cavaites.
Crower / Manley retainers and guides
Crower Double springs, maybe 130# but thinking 150#, need to verify.
Autolite 103's
Cartuning ceramic coated exhaust manifolds, crossover
Custom ceramic coated 3" dp
Perrin Intercooler
Impala HD police radiator and severe duty high velocity cooling fans
Custom Tune
Use Redline 15-50 engine oil
And like John I'm sure it's missing something here...
•H13 piston pins
Double Roller Chain
OEM throttle body
L26 Plenum
ZZP HV3 insert
Billet vacuum block
Autolite 103's
Perrin Intercooler
Custom Tune
