Whats this mean?:flickering dash,headlights...
Old Dec 13, 2008 | 08:32 PM
jeffsmonte's Avatar
Default Whats this mean?:flickering dash,headlights...
What does it mean when your headlights and your interior lights(radio,gagues) flicker a little, as well as the battery/ volt gague moving around when driving. Could it be do to the really cold weather. Is is a weak battery or altenator?
Old Dec 14, 2008 | 06:44 AM
RocknSS04's Avatar
Default RE: Whats this mean?:flickering dash,headlights...
Could be a couple of things. Start with the battery, but if it ONLY happens when driving, it might be the alternator or some bad connections or wiring. The moving of the voltmeter indicates to me that your alternator is giving out. It is possible that it's the BCM, if it is accompanied by clicking noises, but that's not usually going down the road, and the voltmeter should stay solid.
I believe it's a charging system problem. That's what your voltmeter is telling you. Might even be just a corroded connection at the battery. Start with the connections, then the battery, then the alternator, but again, I'm guessing the alternator.
Old Dec 14, 2008 | 07:41 AM
steelmalu43's Avatar
i was guessing the battery or the alternator. Do you have any aftermarket audio equipment?
Old Dec 14, 2008 | 06:07 PM
MrCheesefood's Avatar
My dome light does a slow strobe when I put the rear window defroster on. Its kinda like my own sub zero 5am disco party. New Battery and the Alternator looks newish.
BIG AL 070
Dec 20, 2012 08:31 AM
Berg01SS
Jul 21, 2009 08:59 PM
bkcc64
Apr 19, 2008 07:50 PM
bkcc64
Apr 18, 2008 08:39 PM
bkcc64
Apr 16, 2008 11:03 AM
