Weird monte issue with traction system 0.o
Old Aug 14, 2011 | 09:24 AM
Franks 03SS's Avatar
2011 Monte Of The Year
Default Weird monte issue with traction system 0.o
So the weirdest thing happened with the monte last night! Went ice skating with the gf in Orlando, after an hour or so of driving back home, out of no where the SERVICE TRACTION SYSTEM message came on, as well as the ABS and TRAC OFF light, so I pull over and turned the car off and back on and the lights went off so I just ignored it. Kinda scared me for a bit tho. Anyone know what might've caused that?
Old Aug 14, 2011 | 09:31 AM
We talk about it at least once a week here :P
It's a wheel hub bearing, giving a code that one of the tires aren't spinning. Either a connection is dirty, or a hub is starting to go bad.
Old Aug 14, 2011 | 10:37 AM
do the rear hubs have ABS too? because ive already replaced my 2 front ones not too long ago remember
i need to get under there and check the connections then
Old Aug 14, 2011 | 10:41 AM
Yes the rear can also do this. My last issue with this 2 years ago was a rear.
Old Aug 14, 2011 | 10:43 AM
ahh well i guess im replacing both of them soon then :p
none of the lights came back on tho
Old Aug 14, 2011 | 11:29 AM
Doesn't ALWAYS mean it's the hub. Could just be a connector, could have just been a fluke where one of the wheels said they weren't spinning.
Don't worry about it. If it pops back on you can always take it to a shop and have the ABS code read.
Old Aug 14, 2011 | 12:55 PM
Yea well true
Thanks mike
Old Aug 14, 2011 | 04:37 PM
Make sure nothing messed up the wires. My '94 Grand Am has an ABS sensor outside the wheel hub (reads a spline on the CV half shaft). Some how the wiring for one side got destroyed resulting in a non-functioning ABS sensor until it was fixed.
Old Aug 14, 2011 | 06:15 PM
i will take a look tomorrow when i have time, thanks maniac
Old Aug 14, 2011 | 07:27 PM
If u do end up replacing the rear hubs ive got a drivers side gm one id sell cheap, its brand new bought it for my car but nvr used it
