6th Gen ('00-'05): Transmission problems
Old May 20, 2018 | 01:17 PM
Ranzy's Avatar
Default Transmission problems
My output shaft on the drivers side coming out the transmission moves up and down like crazy any idea on what it might be and how to fix it
Old May 20, 2018 | 05:34 PM
Jeffs02rwdSS's Avatar
Sounds like the shaft bushing is worn out. I believe you need a special tool needed too change it
Old May 21, 2018 | 12:45 AM
Ranzy's Avatar
you wouldn’t know how far into the transmission you have to go to change it would you
Old May 21, 2018 | 02:55 AM
If it's only the bushing you should be able to pull the axle and use the the tool to pull out bushing. If the bushing support is worn you might need transmission. Any way around it you'll need a special tool which most stores won't have unfortunately. I've only seen this changed once on a fwd transmission haven't personally done one bit have done bushings on a 4 wheel drive transfer case and a rwd transmission. Good luck.
