Transmission Flush or Forget About It?
Old Jan 8, 2008 | 04:52 PM
04 Intimidator's Avatar
Default RE: Transmission Flush or Forget About It?
I would forget the flush, but change the fluid and filter.
What is cheaper $60 or so in service or $3000 because you "thought" everything was good.
Old Jan 8, 2008 | 06:09 PM
2000LS's Avatar
my stance is still whatever the owners manual says...
just wanted to defend flushing transmissions... heres basicly how it works, normally the transmission fluid pump pumps fluid to the transmission cooler and then back to the transmission. when you flush a tranny you put the machine in series somewhere in the transmission cooler circuit. the transmission pump pumps out fluid to the flush machine as the flush machine returns clean fluid to the transmission on the return line.
as far as flushing anyything and everything through your transmission, only in the sense that your transmission fluid pump is doing that all the time already.
the benifet of the flush is that you can flush the trans with a greater quanity of fluid than it even holds, leaving you with nice clean transmission fluid. too bad the old filter is still in there. when you drop the pan, change the filter and refill, you only change about half the fluid, leaving you with cleaner, but not clean fluid. either service is better than no service.
so whats best... flush the trans then change the filter
Old Jan 8, 2008 | 06:12 PM
GrandPaDave's Avatar
I third and fourth everyone's suggestions.
Have never liked the power flush.
Changing the filter and the 4-6 quarts is sufficient.
Have never believed that they can change all 14 quarts with that machine.
Otherwise the dealers would be doing it too.
Old Jan 8, 2008 | 06:15 PM
2000LS's Avatar
the dealer i work for and most others do it, atleast around here, we have a machine that will flush up to 20qts through
Old Jan 8, 2008 | 06:17 PM
ORIGINAL: 2000LS
Interesting info, I haven't had a dealer here offer me a "power flush" even though they do offer filter and fluid changes.
Old Jan 8, 2008 | 08:23 PM
RocknSS04's Avatar
ORIGINAL: 2000LS
And what about your dirty filter? Sorry, I don't buy into this scam! Easy money for the service department, and ANY good ASE tech will tell you that, just ask them!
I want my filter changed, just like I want my engine oil filter changed.
Old Jan 8, 2008 | 09:27 PM
2000LS's Avatar
any 'good' ase tech ...i must not have a clue with 9 certs and only 7yrs experience along with over 100yrs combined experience at the shop i work at, with noone there who could know any better how to service a vehicle, everyone who prodiveds a service must be a scammer.
Old Jan 9, 2008 | 03:57 AM
RocknSS04's Avatar
ORIGINAL: 2000LS
I'm not refering to service, but the flush. Why would anyone want to run 20 qt's of whatever fluid is in the machine through a sensitive transmission WITHOUT changing the filter? TWENTY QUARTS? My techs say no to flushing, and even my service manager at the Chevy garage is indifferent to it. He admits he doesn't flush HIS vehicles, but has them serviced. It's a quick and easy $100.
Old Jan 9, 2008 | 02:21 PM
I'm confused, is the flushing fluid NOT transmission fluid?
Old Jan 9, 2008 | 03:09 PM
RickCoMatic's Avatar
The way the Tech at AAMCO explained it to me is they have a Machine which they connect to the Lines going into the Transmission Cooler. The Line from the Tranny to the Cooler is where the Transmissions Fluid will be collected ... and later discarded. The Line FROM the Cooler back into the Transmission is where the New, Fresh Fluid is sent into the Tranny. As the Old Fluid comes to the cooler ... the Machine collects what would be going into the Cooler and replaces what is being sent to be cooled with Fresh,, New Fluid.
There are two large transparent cylinders on the front of the Machine. You see the Fluid exiting the transmission fill-up one of the transparent cylinders while you watch the Other cylinder ... filled with New Fluid ... send its contents back into the Tranny.
Jiffy-Lube offers a similar service. They call their Machine: "T-Tech"
http://www.mytoolstore.com/clore/ttech.html
21
Sep 13, 2012 11:45 PM
Caffenated1
Apr 10, 2011 03:15 AM
Ricks 2006 SS
Mar 24, 2011 02:44 PM
nascar43
Sep 11, 2010 03:43 PM
ashleymc34
30
Nov 1, 2009 10:03 PM
