Opinion Needed: Top of piston head (cylinder 1)
Old Mar 13, 2017 | 05:48 PM
Bleedintoone's Avatar
Default Top of piston head (cylinder 1)
I had a misfire from cylinder one and currently and in the process of cleaning and rebuilding my fuel injectors so out of curiosity I decided to get a camera and check out the piston in cylinder one but the problem is I have no clue what to look for but I did manage to get this picture and I cant tell if it is carbon buildup or what, the reflection of the led doesn't help.
Thanks for the help
Old Mar 14, 2017 | 06:26 AM
turbo monte's Avatar
I can't see anything in that pic to say if there is an issue or not.
Old Mar 14, 2017 | 07:12 AM
Default I will try to get a better picture
If you can enlarge the image that is the very top of the piston you can see the edge of it at the bottom
Old Mar 17, 2017 | 07:36 AM
I'm with turbo, for some reason that image is extremely low resolution. Maybe your camera was set on the lowest setting or maybe you saved and posted just a thumbnail instead of the actual image?
Even enlarged full screen on my phone I can't read the words printed on the tool, much less try to figure out what the image on the screen is showing.
