6th Gen ('00-'05): three light problem (abs)
So ive got the three light issue. Codes pointed to the LR speed sensor so I replaced that. It worked with the key on acc but when I started the car all 3 lights came back on. Now its constant again. Sometimes they go out randomly then ckme back on. Im at a loss. Wireing looked fine.
Computers can go bad... And harnesses are known for going.... And yes it may look fine doesn't mean it always is.... Take it to dealership or somewhere that reads abs and they will tell you. If it said left speed sensor and you didn't replace the wheel bearing that's the problem. Just cuz it looks fine don't mean it is
