T-Stat or U-Bend delete?
Old Nov 9, 2008 | 10:22 PM
03SS's Avatar
Default T-Stat or U-Bend delete?
Hey Guys,
I was woondering wich would give me more noticable power?
A 160 degree drilled T-stat from zzp or The U-bend delete.
My cureent mods are Wizaired CAI, 2.5 inch cat back, and a HV3 intake.
Old Nov 9, 2008 | 10:32 PM
RickCoMatic's Avatar
Default RE: T-Stat or U-Bend delete?
Do the U-Bend Delete.
The 160 Stat is going to put you outside the parameters of several Sensors.
Your CEL comes on because the Coolant Temp Sensors need to be closer to 175/180 to be copacetic.
Old Nov 10, 2008 | 09:47 PM
Blown04SS's Avatar
i would do the u-bend delete...did it on my old grand prix gt and it did make a difference
just a quick question, why...if you are supercharged....did you get the HV3 insert?
Old Nov 11, 2008 | 09:32 AM
03SS's Avatar
im not supercharged
I didn't make my sig
Old Nov 11, 2008 | 01:22 PM
Blown04SS's Avatar
oooh ok
Old Nov 11, 2008 | 06:29 PM
kweef's Avatar
u bend but i doubt ull notice the minimal horsepower u will gain
Old Nov 11, 2008 | 09:51 PM
drewskie043's Avatar
yeah i agree with everyone else, go with the u bend delete. 160 degree tstat is way too cool imo to run your engine at. you won't get your engine up to the right operating temp then you start damaging cylinder walls etc. if you go w/ a different stat, go with a 175-180 degree, then you will want to be able to tweek your ECU so it will turn your rad fans on at 180 instead of the stock setting.
Old Nov 11, 2008 | 10:15 PM
kweef's Avatar
u could reprogram ur pcm to start the fans at 160 too....what many ppl dont know is that a lower temperature tstat is only needed when you are producing excess heat thru something like forced induction. otherwise a different tstat does nothin but reduce gas milage
siouxcity04montess
Aug 15, 2010 12:23 AM
Kelt
May 6, 2007 12:25 AM
jimmy2blazer
Apr 2, 2007 11:44 PM
01blackmonte
Dec 10, 2006 08:42 PM
mcarloss04
Jul 26, 2006 02:58 PM
