Still having the same problem!!!
Old Jan 18, 2008 | 01:36 PM
jeffsmonte's Avatar
Default Still having the same problem!!!
As some of you guys may remember, i installed the k&n intake, and soon after got a service traction control message, abs, brake, and tract off lights. Well I brought it to the dealer to figure out what the problem was. Of course they blamed it on the new intake. That pissed me off, because I had this problem a year ago, without the intake, but that didnt seem to matter to them. $215 later, they said that damned ground strap thing wasnt screwed on tight enough. I figured that to be b.s. though because I know i screwed that thing in very tightly. So I was stuck paying $215 to screw in a screw!!? 4 DAYS LATER I GET THE SAME PROBLEM (the message and all the lights)!! But they did say that their work is guarranteed, so hopefully this time around I wont have to spend a cent!!! What do u guys think? Any advice/comments are appreciated. By the way, its an 03 ss.
Old Jan 18, 2008 | 02:08 PM
Default RE: Still having the same problem!!!
Hi `Jeff,
I'm sorry to read that you are having problems with
your 03 SS : (
It sure can be expensive to own a car & keep up
with the repairs.
Below is a site that I go to for solutions to some of
the problems on Monte Carlo's.
It's hard to give you a direct answer to your problem
without having the equipment to test it.
I hope the below site gives you some idea's or hopefully
a solution to your problem. Click the below links & explore
the site.
Knowledge is power & can
save you big bucks. Wish you good luck. Please
post your results when your problems is discoverd.
`Space
View Full Version : 2000 Monte Carlo Traction Control Problem.
[hr]
Old Jan 18, 2008 | 04:11 PM
jeffsmonte's Avatar
Interesting. Thanks.
Old Jan 18, 2008 | 05:41 PM
[align=center]HI `Jeff,[/align][align=center]When the dealer checked your Monte, did it throw any codes.[/align][align=center]Did they check your MAF Sensor ?[/align][align=center]Did they do a test on your auto `puter ?[/align][align=center]From my search of your problems, it seems that they are[/align][align=center]many owners that have their traction lights come on, [/align][align=center]and the dealer/mechanic can't find anything wrong.[/align][align=center]Some were rear wheel sensors.[/align][align=center]Keep us posted on the results/problem...Good Luck, `Space[/align]
TexasDvlDog
Feb 9, 2015 08:06 PM
RhetoricCamel
Feb 1, 2013 07:50 PM
95montecar
Jan 30, 2013 01:26 PM
GreenRaccoon
Oct 4, 2011 02:21 PM
king72467
Jul 23, 2010 05:35 PM
