Snapped left front wheel stud
Old Nov 4, 2012 | 07:08 PM
Lorenzo's Avatar
Default Snapped left front wheel stud
So after i finished putting on 4 new calipers because 2 of 4 were seizing and putting on the new lower control arm and tie rods, i started torquing my wheels to 100 ft pounds ( Specs recommended 103) Went through 24 out of 25 lug nuts and the last one snapped on me before i was able to get it to click So now i need to replace it. How hard is it to do and what part number is it ? or is it just a general thing to call up Napa and say i need this part? Teacher recommended i get it from the dealer, what do you guys think and has anyone replaced a stud before? Thanks!
Old Nov 4, 2012 | 07:17 PM
Its a real simple fix....
Get a good size BFH...and punch to knock it out the back of the plate(hub)..
Take it with you...and go to your local auto parts and have them look it up...and use the broken one to be sure he got you the correct one....
Also get a few washers that fit it...(5 0r 6 should be more than enough)
Push the stud back thru the hole like it should be...add the washers on the opposite side (where the threads are) and use the stud nut to tighten against the washers to repress the stud in place...Once its seated in place...remove the washers...instahl your tire back on the vehicle...and your all set!
Old Nov 4, 2012 | 07:41 PM
Pretty much sums it up there pretty easy to do
Old Nov 4, 2012 | 07:50 PM
It's not to hard to do.. I do it all the time on mail trucks at work..
Old Nov 5, 2012 | 11:49 AM
Lorenzo's Avatar
So i dont have to take the hub off?
Old Nov 5, 2012 | 01:15 PM
Shouldnt, but itll be a tight fit
Old Nov 5, 2012 | 02:36 PM
nitehawkjcb's Avatar
I took mine off when I replaced a stud, just need a vice and a hammer, pound it out and pound the new one in.
DonnaAnd
Jul 20, 2015 09:25 AM
Monte_Mel
May 2, 2014 11:05 AM
Shandley
Oct 2, 2012 07:21 PM
KWJR86
Apr 8, 2012 09:30 PM
