Should I use premium 92 octane in my 07?
Old 01-11-2012, 04:17 PM
LunarQuartz07's Avatar
Default Should I use premium 92 octane in my 07?
What octane do you use? I have the 3.5 Flex engine in my 07 and I use 92 premium.
Old 01-11-2012, 04:34 PM
joeykl66's Avatar
i use premium in my 07 ss. been told it does and doesnt make a difference. so?
Old 01-11-2012, 04:40 PM
I only use premium in my GTO everything else i use regular
Old 01-11-2012, 04:55 PM
i dont see the point unless you have a pcm tune.
Old 01-11-2012, 05:19 PM
xxtheshockerxx's Avatar
RED DEVIL
i would pry just put regular in it.
Old 01-11-2012, 05:23 PM
I use regular...Is your car the same color as mine? Mine is called Black Amethyst. Not sure about lunar quartz.
Old 01-11-2012, 05:25 PM
RED DEVIL
it might i think the caddys that have your color on them are called lunar quartz.
Old 01-11-2012, 06:02 PM
Regular unless the owner's manual/the manufacturer or the inside of the fuel filler door specifies premium (at least it did on other cars I know that require premium).
Old 01-11-2012, 06:50 PM
Default My 07 is Lunar Quartz Metallic code 320N
Your purple (Black Amethyst) is in the brochure but mine isn't and I can't figure out why. I can imagine why they would offer two different purples on 07 that are so similar. I've only see your color on SS cars though. Mine's an LT that decoded as 1 of 1? There's no way that can be right.
Old 01-11-2012, 06:53 PM
Default When I look for info on the web about my color I get Caddy links.
But I don't get any Monte info on the web for this color, only Caddy.
Quick Reply: Should I use premium 92 octane in my 07?
