Should I do a tune up.
Old Jan 15, 2013 | 08:45 AM
dan_the_man's Avatar
Default Should I do a tune up.
I recently replaced my fuel filter, did a fuel system cleaning, trans flush, coolant flush, power steering flush, replaced intake gasket and manifold gaskets. Also I use synthetic or synthetic blend oil with a fram oil filter. I'm at 106K miles I've always heard that doing a tune up on the 3.8 is difficult and what are the best plugs and wires to use and what's the best gas to use.
Old Jan 15, 2013 | 08:49 AM
use regular gas with a 3800, premium if you are supercharged. AC Delco plugs and wires.
Old Jan 15, 2013 | 11:02 AM
Thank you Chibi. What brakes and rotors would you recommend?
Old Jan 15, 2013 | 11:03 AM
I like Centrix Premium rotors and Bendix ceramic pads
Old Jan 15, 2013 | 11:52 AM
Stay away from Bosch plugs. AC Delco prefered, but I've also seen that AC Delco outsources to NGK. I've used NGKs in some of my GM v6 cars and ZERO issues.
Changing plugs on the 3800 non-SuperCharged are easy, just take your time.
Old Jan 15, 2013 | 12:20 PM
Should change the coil packs too?
Old Jan 15, 2013 | 12:22 PM
No, the coil packs don't need to be regularly changed until there is a problem with them.
My stock ones lasted over 185,000 miles and I never had a problem
Old Jan 15, 2013 | 03:22 PM
Thanks Chibi and The_Maniac. Also I'm wondering if I can install HUD in my car?
Old Jan 15, 2013 | 05:17 PM
You can if you grab all of the stuff from a grand prix, cut your dashboard, etc. It's really not worth it, not many have successfully completed that.
Old Jan 15, 2013 | 06:33 PM
Like the ones in the high sport package monte.
I meant the driver information center
