Service Traction System Light -_-
Disconnect and make sure there's no dirt in the sensors and reconnect them again, open the abs box in the engine bay and clean it out if its dirty. If that doesn't help find a trusty mechanic.
Again, I highly recommend a Timken bearing. It's made here in the U.S.A., they have a great track record for reliability. Using RockAuto, I can typically get a Timken bearing for a W-Body car for $100 to my door. Saving $10-$30 to get a cheaper one is NOT worth it. I've gotten good at doing the front bearings on GM FWD cars (about an hour flat), but I certainly don't want to do it in 1.5 years because I tried to save a couple dollars per bearing (been there, done that, won't do it again).
Removal is simple, BUT, IMO, if you don't have access to a tool called an Air Hammer, DON'T BOTHER! The hub is "pressed" into the steering knuckle, the air hammer lets you quickly and easily pop it out by working it into the sides (after you get the 3 bolts on the back of the hub/knuckle removed and the axle nut). If you try pounding the hub out, get ready to spend some more quality time and a work out. GM recommends a "puller" for the job. I have never used one, never had it available, but the air hammer has never failed me.
You can check the wiring. I believe you can do the fronts without lifting the car, just turn the wheels hard one way, inspect one side and then turn hard the other way and inspect the other side.
![Wink](https://montecarloforum.com/forum/images/smilies/wink.gif)
If your car has high miles and the hubs are original, I would personally change them anyway, now that the sensors are in question. As Maniac said, the abs sensors are built into the hub assembly and cannot be accessed.
how hard is it to replace a wheel bearing? this might be my summer project because my abs and tracktion light are also on
As for pounding it out without an air hammer all depends on how hard that thing is in there. I've had a couple hubs that even with the air hammer were difficult to remove (I could not imagine using the puller or pounding them out by hand).
What I was providing is simply a recommendation based on my experience for the easiest way to accomplish the job at hand.
Not very hard with the right tools and knowledge. This is one of many threads discussing this topic.
![Embarrassment](https://montecarloforum.com/forum/images/smilies/redface.gif)
