security light coming on during driving?
Old Aug 9, 2010 | 12:03 AM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
Exclamation security light coming on during driving?
anyone seen this before? my security light comes on after about 3-5 minutes of driving. just started happening randomly. and now its every time. i hooked it up to my scanner, and it shows "cellular anntenna malfunction". never heard of taht one before. must be something with my onstar? any ways to solve this issue?
Old Aug 9, 2010 | 08:34 AM
Typically the Security light has to do with your passlock system.
Hopefully it doesn't lock you out.
Old Aug 9, 2010 | 08:54 AM
mine came on once but went away after i shut the car off, was passlock an option? because i dont believe my monte has it
Old Aug 10, 2010 | 01:07 PM
Nocturnx's Avatar
Passlock is the anti-theft security, your car has it, it wasn't an option. It is common for it to flake out and prevent cars from starting.
I have not heard of the cellular antenna malfunction code. The security light usually means an issue with the passlock system.
Old Aug 10, 2010 | 04:33 PM
how exactly does passlock work? isnt there a chip in the key?
Old Aug 20, 2010 | 04:03 AM
Photobucket
could this be a possible fuse problem? my security light comes on almost immediately after i start the car, and then it clicks my lights back and forth from DRL's to lights. i can actually hear a "click" each time. happens about every 10 seconds. my volt gauge even takes a hit every time it happens. any ideas?
Old Aug 20, 2010 | 06:24 AM
labnjab's Avatar
Luckily it detects a fault after startup so it probably won't leave you stranded. As for why its turning on, I don't have a clue. That codes doesn't make sense because it doesn't pertain to the passlock system. Do you have a remote starter? Sometimes those will cause problems with antitheft. If I have to take a guess I would say its your ignition switch. Its probably loosing connection internally after start-up, but since the car is already running, it doesn't disable it. I know gm had some problems with the ignition switch and I've replaced a few of them, but they were usually due to a intermittent no start condition
The previous gm security system (passkey) had a chip in the key, but I think they stopped using that late 1999-2000. Passlock is all built into the ignition switch.
Since were on the subject, heres a description of how passlock works, quoted from alldata
The electrical switching portion of the ignition lock cylinder assembly is separate from the key and lock cylinder. The electrical switch portion and the key and lock cylinder synchronize and work in conjunction through the action of the mechanical assembly between the two components.
PASSLOCK(TM) SENSOR
The Passlock(TM) sensor contains 2 hall effect sensors. The tamper hall effect sensor is on the top. The security hall effect sensor is under the tamper hall effect sensor. Both of the hall effect sensors monitor the magnet of the lock cylinder through an opening. The tamper hall effect sensor is physically placed on top of the security hall effect sensor. This arrangement enables the tamper hall effect sensor to engage first if an intruder attempts to bypass the Passlock(TM) sensor by placing a large magnet around that area of the steering column. There is a tamper resistor inside the Passlock(TM) sensor in order to help prevent tamper to the system. Passlock(TM) equipped vehicles have a selection of 10 different security resistors ranging from 0.5K ohms up to 13.6K ohms . Installing one of the security resistors inside the Passlock(TM) sensor will generate a unique Passlock(TM) code. All 10 combinations of the Passlock(TM) sensor have the same part number.
BODY CONTROL MODULE
The body control module (BCM) contains the theft deterrent system logic. The BCM reads the Passlock(TM) data from the Passlock(TM) sensor. If the Passlock(TM) data is correct, the BCM will send a class 2 message to the PCM to enable the fuel injectors and crank relay.
During the tamper mode the vehicle may start. The vehicle will then stall. If the BCM receives the wrong Passlock(TM) data, the VTD system will immediately go into the tamper mode. The tamper mode will lock-out the vehicle fuel injectors and crank relay for 10 minutes . The SECURITY indicator will flash while the VTD is in the tamper mode.
If the Passlock(TM) sensor sends a correct password to the BCM when the ignition is in the ON position, the BCM will send a fuel enable and crank relay enable signal to the PCM.
SECURITY INDICATOR
The SECURITY indicator appears on the message center inside the instrument cluster. If the SECURITY indicator flashes or if the SECURITY indicator lights continuously during vehicle operation, refer to the system diagnosis.
POWERTRAIN CONTROL MODULE
The PCM communicates with the BCM over the Class 2 serial data line. When the BCM determines an incorrect password, it sends a Class 2 serial data password to the PCM in order to disable the crank relay and fuel injection system. If the BCM receives the expected voltage from the Passlock(TM) sensor, the BCM sends a class 2 serial data password to the PCM in order to enable the crank relay and fuel injection system. The PCM then allows the vehicle to start normally.
FUEL LOCKOUT CYCLE
The Passlock(TM) system has a lockout cycle of approximately 10 minutes . Once the vehicle is in the lockout cycle, the vehicle remains in the lockout cycle for 10 minutes , even if the ignition switch is turned from the ON position to the OFF position.
The Passlock(TM) system uses the lockout cycle in order to synchronize all of the Passlock(TM) components when any Passlock(TM) related part is replaced. The Passlock(TM) system requires 3 consecutive lockout cycles in order to complete the 30 minute learn procedure for a changed component.
CHANGING THE PASSLOCK(TM) COMPONENTS
The design of the Passlock(TM) system is to prevent theft even if the various theft deterrent parts change. The parts that can no longer be changed without the possibility of going into a tamper mode are:
* The Passlock(TM) sensor
* The BCM
* The PCM
If you replace any of these parts the vehicle may not start for 10 minutes . This is the long tamper mode. If this occurs, the system must go through a long tamper mode cycle. During this time the SECURITY indicator will be flashing for the full 10 minutes and DTC B3031 will be set. The BCM and the PCM require the full 10 minutes in order to complete a learn cycle. The ignition switch must remain in the ON position until the SECURITY indicator stops flashing. You will need to repeat the cycle if the ignition switch does not remain in the ON position. When replacing any of the above parts, perform the Programming Theft Deterrent System Components procedure.
The design of the Passlock(TM) system is to prevent the vehicle operation if the proper ignition key is not used in order to start the vehicle. The mechanical key, in normal operation, will turn the ignition lock cylinder. The Passlock(TM) sensor monitoring the position of the lock cylinder will relay the Passlock(TM) data to the body control module (BCM). The BCM will determine the validity of the Passlock(TM) data. The BCM will send a password to the powertrain control module (PCM). When the PCM receives the correct password the PCM allows the crank relay and fuel injectors to operate normally. The Passlock(TM) system requires the PCM and the BCM to communicate the various functions in order to operate. These functions transmit over the class 2 serial data line. For an explanation of the class 2 serial data description and operation refer to Data Link Communications Description and Operation in Data Link Communications.
Old Jun 16, 2013 | 09:00 AM
severus snape's Avatar
thanks! this info is quite informative
EbonyChevyMama
Jan 1, 2015 06:41 AM
sunset_ed
Sep 22, 2010 06:51 AM
isnms
Feb 10, 2008 04:41 PM
BeachBumMike
Feb 14, 2007 10:07 AM
